4age 20v A/T ecu
07-09-2008, 09:52 PM
4age 20v A/T ecu
can i run my 4age 20v with an automatic transmission ecu if i have a manual transmission? will the engine loom fit?
07-09-2008, 10:20 PM
4age 20v A/T ecu
the automatic transmission would initiate the clutch and shift procedure. Don't think that is a winner. Just go standalone.
07-09-2008, 10:23 PM
4age 20v A/T ecu
in my Nissan i can use a auto ecu on a manual car without any problems..
07-09-2008, 10:27 PM
4age 20v A/T ecu
yep it's possible, you have to find the wire for the Park/Neutral signal in the loom and connect it to ?? (12V i guess), otherwise your car won't start, because the ECU thinks it's in Drive
07-09-2008, 10:40 PM
4age 20v A/T ecu
it is a manual loom, so there wont be a park or neutral wire.
but there must be a pin on the ecu that is park or neutral. |
07-09-2008, 11:01 PM
4age 20v A/T ecu
yeah, that's what i mean.
If you're unlucky, the connectors aren't the same on the ecu and loom "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
07-13-2008, 10:52 PM
4age 20v A/T ecu
I've heard rumors as well that thhe A/T has a higher redline, and that switching on the extra wires is a piece of cake.
07-14-2008, 10:21 PM
4age 20v A/T ecu
Yes that higher redline might be interesting too, but no one over here used a A/T ecu?
20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 2,310 |
Ecu for AE86 4AGE | Steller Engineering | 6 | 5,211 |
03-10-2021 11:06 PM Last Post: Ivan141 |
20v BT conversion ECU | izanagi | 5 | 6,851 |
06-14-2016 02:39 PM Last Post: izanagi |
20V blacktop. what kind off ecu??? | slowboy2 | 11 | 13,837 |
07-17-2015 07:01 PM Last Post: jdm86gtz |
4age 16v oem ecu rev limiter research | ditn | 18 | 28,217 |
06-22-2015 08:02 AM Last Post: ditn |
