4age intake side (port) dimensions
03-01-2011, 08:49 PM
Hi
Does anyone have sketch/drawing of 4AGE head intake ports, with all dimensions ? Need it for small port, but big port should be useful. thanks |
03-01-2011, 11:33 PM
I can give you that, but not before tomorrow afternoon.
03-02-2011, 07:00 AM
There is a drawing of the intakeport incl. measurments for both small and bigport intake and exhaust in the TRD bible, available here: http://www.aeu86.org/viewtopic/ae86-owne...c/start=50
In case the above link doesn't work here is another http://www.ae86.hu/downloads/?dl_cat=5 You would be after the two Group A manuals I'm online on my phone else I would have posted the measurments AE86 ex-daily |
03-02-2011, 09:57 AM
TRD Bible only give the size of the port, not "all dimensions"
(I believe it's for making custom intake manifold ?) |
03-02-2011, 10:23 AM
I've already searched the bible and i couldn't find it.
And yes, I need it for making custom manifold . What is tragic is that i measured big port once and manifold was great, but i lost the measures. Now I want to try smallport head, but since it is just on the way, i still don't have it, I'm trying to find dimensions and to have manifold ready when head arrives. BTW. tomorrow afternoon is great Thanks |
03-02-2011, 10:38 AM
well don't know if you need more info than that but here goes... freshly out of the bible (dimensions of the smallport)
AE86 ex-daily |
03-02-2011, 04:14 PM
For AE92: yes
but I am pretty sure this is for bigport |
03-02-2011, 04:23 PM
bigport has ~15mm radius in the corners as far as I'm concerned...
but feel free to post measurments if you have. AE86 ex-daily |
03-02-2011, 04:34 PM
the radius on bigport / smallport are pretty much the same
The difference is the length of the port bigport is around 65mm when smallport is around 52mm Anyway I will give the exact size after my work |
03-02-2011, 05:06 PM
It looks that fixing point are the same, and that biger ports are bigger to one side.
Could be even the same height, so just center point and width is the same. |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 17,414 |
08-16-2018 01:36 AM Last Post: Bean |
Small Port Swap | Alex170984 | 1 | 4,189 |
11-21-2016 01:46 PM Last Post: Alex170984 |
Small Port 10.3 Pistons | Alex170984 | 1 | 4,355 |
10-25-2016 09:18 PM Last Post: oldeskewltoy |
Quick question - Brake Pad Dimensions | Lt86 | 2 | 5,354 |
06-07-2015 12:08 AM Last Post: jondee86 |
Dimensions clutch master cylinder | bozu | 2 | 6,132 |
04-16-2015 07:11 AM Last Post: bozu |
User(s) browsing this thread: 24 Guest(s)
