4age intake side (port) dimensions
03-01-2011, 08:49 PM
Hi
Does anyone have sketch/drawing of 4AGE head intake ports, with all dimensions ? Need it for small port, but big port should be useful. thanks |
03-01-2011, 11:33 PM
I can give you that, but not before tomorrow afternoon.
03-02-2011, 07:00 AM
There is a drawing of the intakeport incl. measurments for both small and bigport intake and exhaust in the TRD bible, available here: http://www.aeu86.org/viewtopic/ae86-owne...c/start=50
In case the above link doesn't work here is another http://www.ae86.hu/downloads/?dl_cat=5 You would be after the two Group A manuals ![]() I'm online on my phone else I would have posted the measurments AE86 ex-daily |
03-02-2011, 09:57 AM
TRD Bible only give the size of the port, not "all dimensions"
(I believe it's for making custom intake manifold ?) |
03-02-2011, 10:23 AM
I've already searched the bible and i couldn't find it.
And yes, I need it for making custom manifold ![]() What is tragic is that i measured big port once and manifold was great, but i lost the measures. Now I want to try smallport head, but since it is just on the way, i still don't have it, I'm trying to find dimensions and to have manifold ready when head arrives. BTW. tomorrow afternoon is great ![]() Thanks |
03-02-2011, 10:38 AM
well don't know if you need more info than that but here goes... freshly out of the bible (dimensions of the smallport)
![]() ![]() AE86 ex-daily |
03-02-2011, 04:14 PM
For AE92: yes
but I am pretty sure this is for bigport ![]() |
03-02-2011, 04:23 PM
bigport has ~15mm radius in the corners as far as I'm concerned...
but feel free to post measurments if you have. AE86 ex-daily |
03-02-2011, 04:34 PM
the radius on bigport / smallport are pretty much the same
![]() The difference is the length of the port bigport is around 65mm when smallport is around 52mm Anyway I will give the exact size after my work ![]() |
03-02-2011, 05:06 PM
It looks that fixing point are the same, and that biger ports are bigger to one side.
![]() Could be even the same height, so just center point and width is the same. |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 18,204 |
Small Port Swap | Alex170984 | 1 | 4,360 |
11-21-2016 01:46 PM Last Post: Alex170984 |
Small Port 10.3 Pistons | Alex170984 | 1 | 4,513 |
Quick question - Brake Pad Dimensions | Lt86 | 2 | 5,533 |
06-07-2015 12:08 AM Last Post: jondee86 |
Dimensions clutch master cylinder | bozu | 2 | 6,389 |
04-16-2015 07:11 AM Last Post: bozu |
