4agze distributor??
08-15-2009, 09:04 PM
4agze distributor??
I have some problems with the distributor from my 4agze engine
first prob is that the cables d'ont fit in the distributorcab and second
the conector colour d'ont match (light grey/dark grey?)
so is it possible that it is the wrong cap? or the wrong distributor?
the partnumbersticker is gone so i can't check it Confused
and i can't find a conection or wire for the lamdasonde
i hope tha somebody can help.thx!!
daily driver avensis 2.0 d4d and Yaris 1.0
weekend driver 1985 AE86
08-15-2009, 09:06 PM
4agze distributor??
here are some pics of the problem
08-16-2009, 11:29 AM
4agze distributor??
Looks like someone just grabbed a random set of leads thay had lying
around, and used them to get the engine running. But the distributor
looks about right... the later engines had the leads facing upwards.
If the plugs fit together correctly, you should be fine.
Depending on what car you are fitting the engine into, there may only
be a single wire for the O2 sensor. Early AE86's used unheated sensors,
so you may have to get creative with the heater wiring Smile
Cheers... jondee86
08-16-2009, 12:37 PM
4agze distributor??
so if i change the spark plug cables then it shall be ok then?
08-16-2009, 01:36 PM
4agze distributor??
as I see you have smallport cap on your distributor. smallport has 5mm plug leads, the older engines have 8mm. I think this is your problem. You can get a cap from mr2 aw11 and it should be fine.
08-16-2009, 01:41 PM
4agze distributor??
ok thank you Thumbs up!
  16v distributor hole plug harkes 8 9,508 10-12-2016 11:13 AM
Last Post: harkes
  Changing distributor when carb 4age izanagi 14 15,533 07-04-2016 03:27 PM
Last Post: Uzelac
  Distributor position and cranking pack 13 19,331 07-01-2013 11:08 PM
Last Post: pack
  weak spark. new distributor? please help. stasis_dc5 3 7,153 04-11-2011 12:35 AM
Last Post: fax0815
  distributor prob alex-evo 7 7,295 12-16-2010 12:33 AM
Last Post: alex-evo
