4x100 conversion
12-06-2012, 11:32 AM
4x100 conversion
Stronger axle at same weight as original
Control over rear wheel alignment (grip!) Custom PCDs available Cheap custom axles available from many sources now that the hub is no longer part of the axle. Similar pricing as the weir upgrade (who are also active in dwarf car racing I think..) I'm not sure if current prcing is attractive or not, its just a different option if you're already considering the weir axles. A wheel to steer the front of the car A pedal to steer the rear |
12-06-2012, 02:28 PM
4x100 conversion
the main reason is german inspection bullshit
i bought some bbs rs wheels from djexor but thy are not legal because they never got tested and don't have a kba number. redrilling wheels is also not legal so i like to do this conversion to have a wider varity of legal wheels to choose from, in case of the bbs rs i can go with a bmw wheel so thx for all the input, i look in to it |
12-06-2012, 07:42 PM
4x100 conversion
so you gonna sell the rims again
and why suddenly going streeet legal http://nuudelbahn.wordpress.com/ http://www.superlapbattle.lu https://www.facebook.com/SLBRaceleague |
12-06-2012, 08:57 PM
4x100 conversion
"so i like to do this conversion to have a wider varity of legal wheels to choose from, in case of the bbs rs i can go with a bmw wheel"
I don´t get this point. If you have to change the pcd of the car, then the wheels you are going to mount won´t ever be tested on this car! The KBA number also refers to the car the rims are mounted on... and in case of a hachi, there will be a very small variety of street legal rims in Germany. AE86 Full Hybrid - Burns rubber and gasoline |
12-06-2012, 09:19 PM
4x100 conversion
Why not just change the wheels to legal ones when you go to the inspection? 95% of modified cars won't pass inspection. Look at the german vag scene. Most of those cars are slammed and drive on deepdish wheels.
ハチロク |
12-06-2012, 09:32 PM
4x100 conversion
yeah probaply nbu :wink:
yeah georg you are right, but the wheel itself is tested and if it doesn't hit anything on the car, you can get them into your paperworks zenki because if i get pulled over by the cops, they can take down my car because of possible road safety issues |
12-06-2012, 10:30 PM
4x100 conversion
If you say so... Good luck!
12-06-2012, 11:26 PM
4x100 conversion
I love living in the UK none of this TÜV bollocks,
I sugested redrilling the rear axles/ front hubs is the fastest/ easiest/ cheapest solution an noone ever will know/ see the difference. There should be no problem with the "Einzelabnahme" either, all later Toyotas came 4x100 so the Inspector will not question it in any way! If you got fresh axles/ alloy front hubs he will definatly get suspicious, and ther will be no paperwork them... Think about it... 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
12-07-2012, 08:45 AM
4x100 conversion
I hate my country for following those awfull german tüv standards. its always a pain in the a....to pass mot....
12-07-2012, 09:52 AM
4x100 conversion
Eifelaner, before you sell the BBS's, could you throw one on a scale for me? Curious about their weight in these beefy sizes.
20v Blacktop conversion.... | Mylesmck | 0 | 420 |
Kouki to Zenki Levin grill conversion? | Mylesmck | 6 | 2,072 |
AFM to Map Conversion | ps13michi | 3 | 3,093 |
Sub panel and rotary-button replacement for Levin -> Trueno conversion | gh0st | 9 | 5,272 |
AE86 single wiper conversion | kazi | 6 | 9,259 |
08-26-2017 08:47 PM Last Post: kazi |
