7AGE - How i did it!
04-09-2005, 11:27 PM
Crimson, got any weblink?
[Image: AEU86 AE86 - 7AGE - How i did it!]
04-10-2005, 12:00 AM
nice work,
so, you basically used the original 7AF pistons, correct?
Hurray! Wave
Punky's Corner
04-10-2005, 12:06 AM
You won't get any real power increase just using the fuel computer, the power increase comes from the 264/256 cams and adjustable cam gears i have. The fuel computer is there to get the fuelling right for them.
The 150 bhp comes from Bill Sherwoods site using the stock ecu.
05-12-2005, 10:49 AM
Finally entered the writeup in the How-to section on the frontpage. Blush
05-12-2005, 03:31 PM
banpei Wrote:Finally entered the writeup in the How-to section on the frontpage. Blush
But the two last writeuplinks aint working, look at the link "http://www.aeu86.org../Writeup/Engine/4AGE_to_7AGE_conversion/55/"
Wave
05-12-2005, 04:10 PM
Wave
Hmmm, bizarre... The editor makes it wrong if I enter it's own domain, eg:
http://www.aeu86.org/Whatever/You/Put/Here
will result in:
http://www.aeu86.org/../../Whatever/You/Put/Here
So, fixed it by removing http://www.aeu86.org.
Weird. Undecided
05-10-2006, 05:13 PM
Did you use an uprated oil pump? Where or who makes them? Has to be 7A version due to positioning of the idler pulley.
Listen to the whine.
Not just a carbon copy.
05-01-2007, 05:35 PM
i've just finished building one of these..
i used the original 7a oil pump - which seems to be enough for the application. the only thing that sucks about the 7a block is that it doesnt have oil squirters to cool the bottom of the pistons (as the later versions of the 4ag do) which could lead to overheating problems if you choose to go turbo down the track..
i'd recommend using ae92 (smallport 4ag pistons) for the conversion as the 7a ones are dished and wouldnt give you a very good compression.
i'll try to get a version of my own build process on the http://www.twincam.info forums with pics soon.
05-03-2007, 07:30 PM
I´ve installed the TOGA high Volume oil pump.....they make those for the 7afe.
My evil Red/Black Panda
My current JDM AE86 project
05-13-2008, 11:25 PM
hi i am new here .
i am wondering wich 4AGE engine did you use? not the silver top right?
  7AGE Build apardal 5 1,174 08-02-2024 12:11 PM
Last Post: apardal
  timingbelt 7age 20V!! slowboy2 3 7,195 06-21-2016 09:41 AM
Last Post: ditn
  7AGE to W58, cluth type? slowboy2 2 5,633 05-25-2013 01:37 PM
Last Post: slowboy2
  Finding TDC on a 7AGE oldeskewltoy 3 6,300 03-30-2013 05:03 PM
Last Post: asyrigos
  7age 16v compression Pif 1 4,815 10-12-2010 09:37 PM
Last Post: Pif
