7AGE - How i did it!
04-09-2005, 11:27 PM
Crimson, got any weblink?
04-10-2005, 12:00 AM
nice work,
so, you basically used the original 7AF pistons, correct? Punky's Corner |
04-10-2005, 12:06 AM
You won't get any real power increase just using the fuel computer, the power increase comes from the 264/256 cams and adjustable cam gears i have. The fuel computer is there to get the fuelling right for them.
The 150 bhp comes from Bill Sherwoods site using the stock ecu. |
05-12-2005, 10:49 AM
Finally entered the writeup in the How-to section on the frontpage.
05-12-2005, 03:31 PM
banpei Wrote:Finally entered the writeup in the How-to section on the frontpage.But the two last writeuplinks aint working, look at the link "http://www.aeu86.org../Writeup/Engine/4AGE_to_7AGE_conversion/55/" |
05-12-2005, 04:10 PM
Widar Wrote:Hmmm, bizarre... The editor makes it wrong if I enter it's own domain, eg:banpei Wrote:Finally entered the writeup in the How-to section on the frontpage.But the two last writeuplinks aint working, look at the link "http://www.aeu86.org../Writeup/Engine/4AGE_to_7AGE_conversion/55/" http://www.aeu86.org/Whatever/You/Put/Here will result in: http://www.aeu86.org/../../Whatever/You/Put/Here So, fixed it by removing http://www.aeu86.org. Weird. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
05-10-2006, 05:13 PM
Did you use an uprated oil pump? Where or who makes them? Has to be 7A version due to positioning of the idler pulley.
Listen to the whine. Not just a carbon copy. |
05-01-2007, 05:35 PM
i've just finished building one of these..
i used the original 7a oil pump - which seems to be enough for the application. the only thing that sucks about the 7a block is that it doesnt have oil squirters to cool the bottom of the pistons (as the later versions of the 4ag do) which could lead to overheating problems if you choose to go turbo down the track.. i'd recommend using ae92 (smallport 4ag pistons) for the conversion as the 7a ones are dished and wouldnt give you a very good compression. i'll try to get a version of my own build process on the http://www.twincam.info forums with pics soon. |
05-03-2007, 07:30 PM
I´ve installed the TOGA high Volume oil pump.....they make those for the 7afe.
05-13-2008, 11:25 PM
hi i am new here .
i am wondering wich 4AGE engine did you use? not the silver top right? |
7AGE Build | apardal | 5 | 846 |
08-02-2024 12:11 PM Last Post: apardal |
timingbelt 7age 20V!! | slowboy2 | 3 | 6,953 |
06-21-2016 09:41 AM Last Post: ditn |
7AGE to W58, cluth type? | slowboy2 | 3 | 5,468 |
Finding TDC on a 7AGE | oldeskewltoy | 3 | 6,060 |
03-30-2013 05:03 PM Last Post: asyrigos |
7age 16v compression | Pif | 1 | 4,693 |
10-12-2010 09:37 PM Last Post: Pif |
