7age real life experiences needed.
10-25-2005, 01:51 PM
Are you running the same revlimit as before?
10-28-2005, 10:07 AM
yes standard rev limit is retained - i had it checked and it was running lean in the high revs but i changed the injectors to small port injectors (pink) and this problem has stopped she runs fine all the way to the limit, however with 7A you do not need to bounce off the limiter all the time as peak power is at 6600RPM so i find myself only reving to 7200 to ensure i drop into the powerband in the next gear Smile
Run Free and take a Goodline
V8FOURCAM32 MK3 Supra
suzuki cappuccino
mondeo TD
10-30-2005, 10:13 AM
ok peoples here it is
the 7a has 2 or 3 bad areas
1 the rods are piss weak and will break if you take it near redline alot
2 the pistons are also a weak area and will need replaced
3 it only has a 6 bolt flywheel
i built a 7agte myself and i run argo rods about 1100 australia dollars and aries pistons$800 and run a porsche 944 timing belt which it also needs
the bore is the same as a 4age so 4age pistons will fit it is just the stroke that is longer it is also an idea to shot peen the crank and run apr bolts for extra strengh any of the small,big 20v heads will bolt up
it is a great engine if built correctly and alot of the clubmans/lotus7s ect run that set up here in australia
1987 majenta red corolla gt coupe
1985 white ae86 7age monster
10-30-2005, 01:02 PM
What would need for this hybrid? 7A block, 4AGE head, Porsche 944 timing belt, but which ECU? 7A or 4A? Any piggyback are required? Any campulleys to adjust timing? The 4A flywheel need to be redrilled or just use the 7A flywheel and clutch?
Two of my friends are considering this project, one with a AT200 Celica (6g)/ 7AFE for a headswap, the other is a hachi possible turboed later.
10-30-2005, 01:25 PM
XJS Wrote:What would need for this hybrid? 7A block, 4AGE head, Porsche 944 timing belt, but which ECU? 7A or 4A? Any piggyback are required? Any campulleys to adjust timing? The 4A flywheel need to be redrilled or just use the 7A flywheel and clutch?
H7ERO wrote his conversion here:
http://www.aeu86.org/Writeup/Engine/4AGE...index.html
[Image: AEU86 AE86 - 7age real life experiences needed.]
10-30-2005, 01:28 PM
i run a motec ecu and a flywheel of a 4ac carby 1600
campullys not necessery but you dont go to all that trouble and not put a set of decent cams in it
10-31-2005, 01:49 PM
Thanks for the info! Great writeup.
11-21-2005, 01:39 PM
H7RO, is it possible for me to talk to you via MSN, or Yahoo?
cheers
My evil Red/Black Panda
My current JDM AE86 project
11-21-2005, 11:07 PM
peter møller Wrote:H7RO, is it possible for me to talk to you via MSN, or Yahoo?
cheers
He does have a hotmail address. Did you try that one already? Dumb question
11-22-2005, 10:31 PM
hello peter, i have a hotmail acount i think i even have a MSN acount il have to check why dont you pop over to england and then you can drive it! Thumbs up! Thumbs up!
suzuki cappuccino
mondeo TD
  7AGE Build apardal 5 887 08-02-2024 12:11 PM
Last Post: apardal
  timingbelt 7age 20V!! slowboy2 3 7,010 06-21-2016 09:41 AM
Last Post: ditn
  7AGE to W58, cluth type? slowboy2 3 5,506 05-25-2013 01:37 PM
Last Post: slowboy2
  Finding TDC on a 7AGE oldeskewltoy 3 6,116 03-30-2013 05:03 PM
Last Post: asyrigos
  7age 16v compression Pif 1 4,710 10-12-2010 09:37 PM
Last Post: Pif
