7age real life experiences needed.
11-23-2005, 04:57 AM
H7ERO Wrote:hello peter, i have a hotmail acount i think i even have a MSN acount il have to check why dont you pop over to england and then you can drive it! Thumbs up! Thumbs up!
Oh man that would be super cool, but i guess the travelling would cost me apprx the same as the bottom end alone, so i think i´ll just build it, and then see if i like it. Not a complete waste of money, theres allways a buyer for an engine like that. Smile
My evil Red/Black Panda
My current JDM AE86 project
11-24-2005, 01:38 AM
thats very true you have not much to lose! it will only take a few days to make and you will be faster i promise! and in the unlikley event you dont like it you will always find a buyer in ae82,ae86,aw11 owners!
further research iv put in sugests going actually for shorter duration cams when the engine has low compression so that to cut a long story short the valves are closed for longer alowing a greater cylinder pressure to be built up. or just go for a shorter exhaust cam? i dont know!
see this link http://www.datsport.com, go to tek section then racer browns camshaft story
other wise putting 4age pistons in will really help your output but will double to work of building the engine!
i have a set of small port cams(the shortest of 4a cam durations) and i will fit them soon and see if they are better!
also the injectors iv found to be best are 4age pink low impedance but im checking out some honda ones at the moment (these will be cheaper and easier to get) so ill keep you posted on that
anyone got any cheap ideas on how to test of there are any gains? i cant aford dyno sessions - might just have to do timed runs?
what do people think about using the small port head on the 7a block will the ports be too small?
i guess its all about testing!
Run Free and take a Goodline
V8FOURCAM32 MK3 Supra
suzuki cappuccino
mondeo TD
11-24-2005, 02:31 AM
As for now, i´m actually builiding mine with the small port head.
Mostly because i bought an ITB adapter for the smallport, so as you have guessed by now, 20V itb´s will be fitted as well.
In connectiong with that, i´ve been looking into installing smallport pistons as well, as they add extra compression (hence the 140hp performance of the smallport) so that should be interesting.
Other than that i have Fidanza camgears, and Schrick 258 cams to be installed.
I have no idea what all this will add up to, but anything around 160hp and big torque will do it for me Smile
Off course a full balancing of the crank + flywheel will be done to see if that will give me the stability to pull the engine to around the 7500-8000mark just as a precaution. Not that i´ve planned to go there regularly anyways :wink:
So thats it for now....
Let me know more when you have additional info Thumbs up!
11-24-2005, 10:49 AM
peter,
Quote:In connectiong with that, i´ve been looking into installing smallport pistons as well, as they add extra compression (hence the 140hp performance of the smallport) so that should be interesting.
Hi-comp pistons use 20mm pins - hence you should use also conrods and cranc from hi-comp. engine.
11-28-2005, 05:35 PM
some new news to 7a people
this weekend i spent testing all the camshafts i had on my 7age
blue top cams
small port cams
piper 252duration cams
and guess what . . . . . . the small port cams are the best even more torque from down low!
i also tested using a larger inlet cam compared to the exhaust cam it just made it slower, my testing was a bit 'gheto' so i cant give you any real figures Dumb question
suzuki cappuccino
mondeo TD
11-28-2005, 07:26 PM
jamiemirror Wrote:peter,
but i think its not possible you have then only 77mm stroke and can use 4ag blockSmile
wiseco build hicomp pistons also for 18mm pins (11,3:1ratio)
http://www.86ers.org
11-28-2005, 08:25 PM
Quote:but i think its not possible you have then only 77mm stroke and can use 4ag blockSmile
The stroke relies just on crank and is the same for 40 and 42mm cranks.
11-29-2005, 01:14 AM
yes but they both are diferent from 7afe crank Smile
12-07-2005, 05:12 PM
a link from club4ag. street dynoed 4age.
http://forums.club4ag.com/topic.asp?TOPIC_ID=118763
Smile
12-13-2005, 07:08 AM
CelicaDrifter from club 4ag built a 7ag thats carbed. Im not sure if hes made a topic about it yet but its probably going to be pretty sick. I also recently read one about a 7agze using a previa super charger 7a block and a large port head with t-vis. I think that guy was in germany. Theres a guy around town running a 7ag, heres a pic, it sits higher and the intake mount doesnt work anymore and cant use a strut bar.
[Image: AEU86 AE86 - 7age real life experiences needed.]
knowtist the oil pump
  7AGE Build apardal 5 665 08-02-2024 12:11 PM
Last Post: apardal
  timingbelt 7age 20V!! slowboy2 3 6,856 06-21-2016 09:41 AM
Last Post: ditn
  7AGE to W58, cluth type? slowboy2 3 5,416 05-25-2013 01:37 PM
Last Post: slowboy2
  Finding TDC on a 7AGE oldeskewltoy 3 6,017 03-30-2013 05:03 PM
Last Post: asyrigos
  7age 16v compression Pif 1 4,651 10-12-2010 09:37 PM
Last Post: Pif
