94 corolla major electrical problems
02-10-2007, 05:43 AM
when i tried to start the engine everything goes off in the car like a dead battery. Checked bat and it's good, next remove starter and had it checked, it was also good. With starter removed installed battery and all lights worked, turned key and heard starter relay clicking. Installed starter and attempted to start the car and again all lights went out and no starter relay clicking. Checked all fuses that were accessible all looked good. What should I do next?
02-10-2007, 05:52 AM
Possible weak wire somewhere, or grounding issues? Don't really know, that's the kind of issue that'd drive me mad if it happened to me. If the relay is clicking without the starter, then it's not ignition issues, which would've been my best guess....
02-10-2007, 06:06 AM
engine ground or chassi gnd? Checked both, good gnd. When connecting bat terminals, sometimes small spark, sometimes not. When spark lights will turn on, if no spark no lights will come on.
02-11-2007, 04:00 AM
check the ground from the battery to the body..
Also, check the ground to the engine and check your + to the starter... (big fat red wire to the starter) SNO-MO-BIRU project started- CHIRO |
Big wheel problems | gh0st | 16 | 8,460 |
Starting problems 4-AGE kouki | Hanzo | 3 | 2,698 |
Problems Mintex M1155 pads | Dino86 | 9 | 9,083 |
07-04-2017 11:22 AM Last Post: totta Crolla |
16v Bigport fuel problems | Rascal21 | 1 | 4,814 |
07-04-2015 01:00 AM Last Post: jondee86 |
Starter problems | Widar | 49 | 122,362 |
02-09-2015 10:11 AM Last Post: Ivan141 |
