AE85 vs. AE86
06-20-2007, 08:17 PM
AE85 vs. AE86
Hi.
I'm about to buy a AE85. I've read about some of the differences between the AE85 and AE86. Basicly it's the engine, the lsd? and some interiour? Can anyone here specify the differences? I'm planning to change the engine to a 4A GZE, is this just as "simple" as changing in the AE86? The body is the same, right? So all the styling and such is the same? Thanks for answers. ![]() |
06-20-2007, 09:48 PM
AE85 vs. AE86
Are you importing the AE85 from Japan/NZ/Australia/Malaysia or are you buying a SR5 spec USDM/EU?
![]() For both the difference is the engine, lsd and interior, however the AE85 does have a K-50 tranny and the SR5 spec does have a T-50 tranny. For both cars you need to change the fuelpump, however you probably would need to change it anyway for a GZE swap. ![]() The body is the same, but on both SR5 and AE85 spec cars you don't have the two-tone panda color schemes. Think that's about it. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
06-20-2007, 11:57 PM
AE85 vs. AE86
It is an AE85 from EU, Schweiz. I don't have much info about it, but the pictures are at:
http://www.need4speed.no/index.php?optio...&Itemid=34 Looks like it sais SR on the back, no 5 number (?). Is AE85 and SR5 two different cars? The car look really good, and I'm getting a good price on it. The plan is to re-paint it anyway, to either the white/black or the red/black combination :wink: Not sure what a K-50 or T-50 tranny is. I'm kind of a newbe, but I'll figure it out ![]() |
06-21-2007, 12:01 AM
AE85 vs. AE86
banpei Wrote:The body is the same, but on both SR5 and AE85 spec cars you don't have the two-tone panda color schemes. Think that's about it. And the brakes are dfferent; front ventilated discs, and rear discs for AE 86, and front non-ventilated discs and rear drum type for AE85. Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
06-21-2007, 12:12 AM
AE85 vs. AE86
God I thought I knew plenty about Ae86's and stuff, I've been learning loads!
Bang her in 1st and make her Tramp Toyota Corolla AE86 GT Rally Car E30 BMW 318is Rally Car |
06-21-2007, 12:53 AM
AE85 vs. AE86
fuel line is difrent from the rear tank and lets not forget the electronics. The ae86 almost has the same wireloom as of an GZE but the SR5 and ae85 don't.
2 thinks I find strange is that the 1.6SR is sold ineurope and second what on earth did you pay for this little car as far as i get on money it seems to be around 6000 euro's ???? Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
06-21-2007, 07:41 AM
AE85 vs. AE86
The price on the page is not correct. I'm getting it for less than 3500 euro's. If I accept it, what do you think? Ok price for a nice car like that, remember I plan to change the engine and paint it
06-21-2007, 08:59 AM
AE85 vs. AE86
well as this car is here in ZH, according to the add on mobil.de it's quite overprized... I payed about that amount for my AE86.
AE86 ex-daily |
06-21-2007, 09:31 AM
AE85 vs. AE86
Syns Wrote:Looks like it sais SR on the back, no 5 number (?). Is AE85 and SR5 two different cars?SR5 and AE85 are different cars. The SR5 spec has a 4AC engine (1600) instead of the 3AC engine (1500) in the AE85. It is also somewhat more luxurious in options, so it could have powersteering and airco but I doubt if that was included in the EU spec SR5. The tranny means transmission. The K50 is, as I understood, weaker than the T50 so using a GZE on a K50 is asking for trouble. The AE86 has the T50 and we've seen several cars being converted to GZE on a T50 without major problems. Meshin: you are right about that, I forgot to mention that as well. That also means if you swap the axle as well you have to swap the brake balancer as well. Robokill: we have already seen a couple of SR5 spec levins through Europe: spitfire in Czech, one in Hungary and another one in Turkey. Most of them were sold in Switzerland. You are also correct on the wireloom: the engine loom should be different but most of it is the same. Easier to swap only part of it. ![]() Syns: I think if you read this topic you can see what you're up to: http://www.aeu86.org/index/engine-ae86-s...post=72098 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
06-21-2007, 10:02 AM
AE85 vs. AE86
Actually Toyota put SR5 grade only as "5-speed gear" meaning
Ae85 swap 4age. | Minidaxman | 8 | 5,781 |
04-07-2021 10:16 PM Last Post: Minidaxman |
ae85 kickdown cable | MIGGZFSU | 0 | 3,239 |
05-04-2017 04:23 PM Last Post: MIGGZFSU |
HELP! need AE85 lisse/lime cluster diagram | AE86_DRIFTER_ | 0 | 3,654 |
06-27-2016 11:38 PM Last Post: AE86_DRIFTER_ |
AE85 axle dif hub to ae86?? | Melo | 7 | 10,716 |
04-30-2012 11:38 PM Last Post: Melo |
Approaches to making the AE85 4WD | 4000GT | 11 | 21,464 |
02-17-2011 10:08 PM Last Post: jameslad |
