AE85 vs AE86
07-16-2010, 07:21 AM
AE85 vs AE86
So is there anyway real way to tell which car is which if you arent there in person? Cause i just remember an episode of initial d where the whole ae85 thing. and i was considering tradin my s13 for what i believe is an AE86 but now i am not sure please help! i do not wanna let go of my S13 for an AE85.
07-16-2010, 07:37 AM
AE85 vs AE86
Sure - just check the firewall for the chassis number - it's stamped in there and will begin with AE86...
http://www.super86.co.nz |
07-16-2010, 09:43 AM
AE85 vs AE86
Different engine, (looks kind of like this in stock form
), has drums at rear axle, different interior....
07-16-2010, 12:29 PM
AE85 vs AE86
Quote:UzelacTrue...although all of that can be changed for AE86 running gear - the only way to be sure is by the number stamped in the firewall... http://www.super86.co.nz |
07-16-2010, 12:41 PM
AE85 vs AE86
Hmm
![]() There are many AE86 converted from AE85. I wouldn't mind having it if it has rear axle with LSD, all disc brakes and 4AGE. In that case, it's irrelevant what's written on firewall ![]() Chances are that converted AE85 is better than stock AE86, most of the guys doing it rebuild the car and/or put better/new parts. Check the car thoroughly , see what's in it and then make decision if you will do some trade. |
07-22-2010, 02:36 AM
AE85 vs AE86
There is only one true Nismo at AEU86 |
07-22-2010, 07:32 AM
AE85 vs AE86
the code can also be ae88, but that = coupe gts.
| Ae85 swap 4age. | Minidaxman | 8 | 10,310 |
04-07-2021 10:16 PM Last Post: Minidaxman |
| ae85 kickdown cable | MIGGZFSU | 0 | 4,613 |
05-04-2017 04:23 PM Last Post: MIGGZFSU |
| HELP! need AE85 lisse/lime cluster diagram | AE86_DRIFTER_ | 0 | 4,985 |
06-27-2016 11:38 PM Last Post: AE86_DRIFTER_ |
| AE85 axle dif hub to ae86?? | Melo | 7 | 13,697 |
04-30-2012 11:38 PM Last Post: Melo |
| Approaches to making the AE85 4WD | 4000GT | 11 | 25,416 |
02-17-2011 10:08 PM Last Post: jameslad |
