AE85 vs AE86
07-16-2010, 07:21 AM
AE85 vs AE86
So is there anyway real way to tell which car is which if you arent there in person? Cause i just remember an episode of initial d where the whole ae85 thing. and i was considering tradin my s13 for what i believe is an AE86 but now i am not sure please help! i do not wanna let go of my S13 for an AE85.
07-16-2010, 07:37 AM
AE85 vs AE86
Sure - just check the firewall for the chassis number - it's stamped in there and will begin with AE86...
http://www.super86.co.nz |
07-16-2010, 09:43 AM
AE85 vs AE86
Different engine, (looks kind of like this in stock form ), has drums at rear axle, different interior....
07-16-2010, 12:29 PM
AE85 vs AE86
Quote:UzelacTrue...although all of that can be changed for AE86 running gear - the only way to be sure is by the number stamped in the firewall... http://www.super86.co.nz |
07-16-2010, 12:41 PM
AE85 vs AE86
Hmm
There are many AE86 converted from AE85. I wouldn't mind having it if it has rear axle with LSD, all disc brakes and 4AGE. In that case, it's irrelevant what's written on firewall Chances are that converted AE85 is better than stock AE86, most of the guys doing it rebuild the car and/or put better/new parts. Check the car thoroughly , see what's in it and then make decision if you will do some trade. |
07-22-2010, 02:36 AM
AE85 vs AE86
There is only one true Nismo at AEU86 |
07-22-2010, 07:32 AM
AE85 vs AE86
the code can also be ae88, but that = coupe gts.
Ae85 swap 4age. | Minidaxman | 8 | 5,021 |
04-07-2021 10:16 PM Last Post: Minidaxman |
ae85 kickdown cable | MIGGZFSU | 0 | 3,084 |
05-04-2017 04:23 PM Last Post: MIGGZFSU |
HELP! need AE85 lisse/lime cluster diagram | AE86_DRIFTER_ | 0 | 3,493 |
06-27-2016 11:38 PM Last Post: AE86_DRIFTER_ |
AE85 axle dif hub to ae86?? | Melo | 7 | 10,105 |
04-30-2012 11:38 PM Last Post: Melo |
Approaches to making the AE85 4WD | 4000GT | 11 | 20,724 |
02-17-2011 10:08 PM Last Post: jameslad |
