AE86 Engine Coolant Temp Sensor
08-31-2014, 09:17 PM (This post was last modified: 08-31-2014 09:44 PM by izanagi.)
Hi all,
I've big problems with my idle and i can't get it lower than 1200rpm.
I cleaned the Idle Air Valve Under the TB, I have not vacuum leaks and when I block the small hole of the TB that control the idle, the idle is still at 1200rpm even with the screw totally down.
Now I guess it is my Coolant Temp Sensor of my TPS.
My Trueno came from Japan with a red top swap and I would like to check the coolant temp sensor but i don't know witch of these two sensors it is.
Can you help me please.
[Image: AEU86 AE86 - AE86 Engine Coolant Temp Sensor]
Thanks
09-01-2014, 09:07 AM
I'd expect the coolant sensor to be at the back of the head, but there are 2 (1 for the cluster, 1 to ecu), and I forgot where the other one is.
Also check your throttle valve adjustment, there is a screw adjustment on it with which you can set the valve opening @ closed throttle.
09-01-2014, 10:35 AM
On European 4AGE, lower sensor is for ECU (green), upper one is for cluster.
AFAIK Japan engines have same green one on back of their heads.
09-01-2014, 11:42 AM (This post was last modified: 09-01-2014 12:19 PM by izanagi.)
(09-01-2014 09:07 AM)Ivan141 Wrote:  I'd expect the coolant sensor to be at the back of the head, but there are 2 (1 for the cluster, 1 to ecu), and I forgot where the other one is.
The screw is completely screwed and my idle is still high.
Envoyé depuis mon GT-I9100 avec Tapatalk
09-01-2014, 05:09 PM (This post was last modified: 09-01-2014 05:15 PM by Bean.)
Have you set the TPS? The sensor has to be adjusted right else the ECU won't go completely into idle mode. You'll find the procedure in the manual.
Also make sure you don't have any leaks in the plenum and that your throttle body flap is closing all the way. After some decades it can use a good clean.
With the idle adjustment screw fully in your engine isn't supposed to run as there's not enough air to get even to 500rpm
AE86 ex-daily
09-01-2014, 05:46 PM (This post was last modified: 09-01-2014 08:35 PM by izanagi.)
(09-01-2014 05:09 PM)Bean Bandit Wrote:  Have you set the TPS? The sensor has to be adjusted right else the ECU won't go completely into idle mode. You'll find the procedure in the manual.
I've already adjusted the TPS.
I have no leaks.
I've putted my finger on this big hole (marked in blue) and the idle drop down and the part (marked in black) has been like blowed.
09-03-2014, 10:18 AM
Up. Someone could help me please.
Thanks
09-06-2014, 03:57 PM
Sounds like the idle speed control valve under the tb is stuck open, It´s like a thermostat, and they sometimes break. Funny enough the picture you are using looks like its my tb, when I had the same problem in 2010. Cleaned it many times, didnt change a thing, got a different throttle body, fixed it.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
09-06-2014, 05:47 PM
(09-06-2014 03:57 PM)fax0815 Wrote:  Sounds like the idle speed control valve under the tb is stuck open, It´s like a thermostat, and they sometimes break. Funny enough the picture you are using looks like its my tb, when I had the same problem in 2010. Cleaned it many times, didnt change a thing, got a different throttle body, fixed it.
I'm searching another TB.
  Lambda sensor wiring sam3007 10 5,819 05-23-2022 10:00 PM
Last Post: The Doctor
  Hall sensor totta Crolla 7 8,988 02-28-2014 10:07 AM
  bad coolant kawo 9 12,286 11-18-2013 07:43 PM
Last Post: Apsogos
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 8,943 10-30-2013 11:18 PM
  Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE Homem Bomba 3 11,995 10-25-2013 05:13 PM
Last Post: Apsogos
