AE86 rear axle weight
02-28-2013, 01:11 PM
Hi all,
Does anyone know the weight of an AE86 complete rear axle (LSD, driveshafts, etc).
Cheers
[Image: AEU86 AE86 - AE86 rear axle weight]
02-28-2013, 09:50 PM
I know for a fact that the complete diffhousing with a TRD LSD weighs 21kg. And the axle itself doesn't bearly weigh anything, can easily pick it up with one hand. As for the rest I have no clue, could maybe weigh it next time I'm down there.
02-28-2013, 11:57 PM
well its for a rear axle that I'm arranging a courier for. needs picking up from Ireland and delivering to the UK
03-01-2013, 02:27 PM
Ok so I was down at the garage today, but forgot to bring a scale Banging head so I had to use the highly accurate method of lifting stuff with my hand and guess. Given that I know what the diffhousing weighs I'd say that a complete rear axle weighs around 50kg.
03-01-2013, 04:40 PM
I'd expect it to be more than 100 kg's.. I can lift a 4age with ancillaries by myself.. a rear axle is heavier than that for sure.
03-01-2013, 04:52 PM
Empty axle is like 30-40kg, heavy but liftable.
shafts, bearings, diff, brakes.. i think it puts it to 70-80kg area.
03-01-2013, 04:56 PM
I would say more like 50-60Kg lifted a spare one I have today.
Restoring my AE86, all the way... Going JDM style Big Grin
http://www.aeu86.org/viewtopic/ae86/p/150463#150463
03-01-2013, 08:23 PM
diff and pumpkin: 18.6kg (OEM, no oil)
axle housing: 15.9kg
axles: 11.5kg (TOTAL for 2 early axles)
rear caliper: 3.1kg
rear disc: 4.2kg
swaybar: 2kg
Total between 47kg and 63.6kg
03-01-2013, 08:44 PM
I miscalculated, forgot that shafts were still in axle when i took it for sandblastnig Smile.
03-04-2013, 09:47 PM
Ivan141 Wrote:I'd expect it to be more than 100 kg's.. I can lift a 4age with ancillaries by myself.. a rear axle is heavier than that for sure.
No way is is more then 100kg Tongue
Thanks NoHachi! I guess I wasn't too far off with my amazing arms of measurement Wink
  Axle width totta Crolla 1 1,056 10-24-2023 12:20 PM
Last Post: FanIsHere
  light weight Flywheel filh 9 7,259 02-05-2018 05:20 PM
Last Post: filh
  Rear axle options Dino86 13 12,873 01-08-2018 10:19 PM
Last Post: ditn
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,780 12-21-2016 09:37 PM
Last Post: bozu
  wider rear axle,track width,suspension questions ditn 6 8,663 10-18-2016 11:50 AM
Last Post: fantapants
