AE86 rear axle weight
02-28-2013, 01:11 PM
Hi all,
Does anyone know the weight of an AE86 complete rear axle (LSD, driveshafts, etc). Cheers ![]() |
02-28-2013, 09:50 PM
I know for a fact that the complete diffhousing with a TRD LSD weighs 21kg. And the axle itself doesn't bearly weigh anything, can easily pick it up with one hand. As for the rest I have no clue, could maybe weigh it next time I'm down there.
02-28-2013, 11:57 PM
well its for a rear axle that I'm arranging a courier for. needs picking up from Ireland and delivering to the UK
03-01-2013, 02:27 PM
Ok so I was down at the garage today, but forgot to bring a scale
03-01-2013, 04:40 PM
I'd expect it to be more than 100 kg's.. I can lift a 4age with ancillaries by myself.. a rear axle is heavier than that for sure.
03-01-2013, 04:52 PM
Empty axle is like 30-40kg, heavy but liftable.
shafts, bearings, diff, brakes.. i think it puts it to 70-80kg area. |
03-01-2013, 04:56 PM
I would say more like 50-60Kg lifted a spare one I have today.
Restoring my AE86, all the way... Going JDM style ![]() http://www.aeu86.org/viewtopic/ae86/p/150463#150463 |
03-01-2013, 08:23 PM
diff and pumpkin: 18.6kg (OEM, no oil)
axle housing: 15.9kg axles: 11.5kg (TOTAL for 2 early axles) rear caliper: 3.1kg rear disc: 4.2kg swaybar: 2kg Total between 47kg and 63.6kg A wheel to steer the front of the car A pedal to steer the rear |
03-01-2013, 08:44 PM
I miscalculated, forgot that shafts were still in axle when i took it for sandblastnig
03-04-2013, 09:47 PM
Ivan141 Wrote:I'd expect it to be more than 100 kg's.. I can lift a 4age with ancillaries by myself.. a rear axle is heavier than that for sure. No way is is more then 100kg ![]() Thanks NoHachi! I guess I wasn't too far off with my amazing arms of measurement ![]() |
Axle width | totta Crolla | 1 | 1,056 |
light weight Flywheel | filh | 9 | 7,259 |
02-05-2018 05:20 PM Last Post: filh |
Rear axle options | Dino86 | 13 | 12,873 |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 3,779 |
wider rear axle,track width,suspension questions | ditn | 6 | 8,663 |
