APEXi SAFCII on gZe???
01-12-2006, 11:47 AM
Hi, most of you know my set-up:
AE86 with late spec map sensored 4agZe, closed blow off HKS pulley, air filter, larger fuel pump bla bla bla... Do you think that a safcII could help the situation or not? danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
01-12-2006, 12:53 PM
Not if you are not going to do any serious tuning...
If you really want to make an improvement, first drop some euro's on a wide-band lambda setup and deduce your fueling needs from measurements not gut-feeling.. If you want to tune your ignition maps, then you really can't go without an exhaust temp probe and knock-pickup. Once you know exactly what you want to do fueling wise, then any system that allows you to do that is just fine..But just adding them blindly is probably a waste of money. PS: Look out for a lambda unit with datalogging capabilities..at least map+rpm+lambda. Send me the logs and I can calculate the exact percentages that you need to change your fuel by and give you a printout of your volumetric efficiency map. A wheel to steer the front of the car A pedal to steer the rear |
01-12-2006, 03:27 PM
euuuhhh???????
01-12-2006, 03:44 PM
Well, this: http://www.diyautotune.com/catalog/innov...a43e8c5785
for example is one of the cheaper wideband controllers, you can hook it up to a standalone ECU, and you can also do some datalogging with a laptop (it comes with a cable for that). Dont know how you would get the rpm logged though. It's probably a lot easier when you can datalog through a programmable engine management. FABRICA MI DIEM, PVNC! |
01-12-2006, 04:05 PM
Excuse me, but isnt the safc that changes the signals going to the ECU so you can djust the fuel dutty circle according to your needs?
If the ECU "reads", lets say, an "A" factor you can adjust it to be "A+" or "A-". So you manage to get a better fuel curve. I m I wrong? danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
01-12-2006, 04:48 PM
Yes, but to adjust the fuel to your needs, you need to know what your needs are! Not just yoggle a button at random.
And to that..you need a wideband lambda+logger Without good measuring tools even the most expensive motec standalone is useless piece of crap... A wheel to steer the front of the car A pedal to steer the rear |
01-12-2006, 04:51 PM
Cant I just meassure the mixture once, before I programm the safc??
Cause its the most logical thing that if I go program the safc we will meassure with a wideband before... But do you mean I have to have a wideband permanently? danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
01-13-2006, 10:32 AM
No, the point is that to get a good picture of what your fuel mixture is like before you go adjusting it, you need to do some wideband O2 measuring.
Then you know exactly where the engine leans out/runs too rich, so you can fiddle with the SAFC to compensate. Then you can test the results of your endeavours using the wideband O2 again. Using wideband permanently is offcourse very nice, but requires a standalone controller, which you dont have. FABRICA MI DIEM, PVNC! |
01-13-2006, 10:34 AM
... or have one just to make the best settings for the APEXi... :wink:
AE86 FANATIC!!! |
01-13-2006, 10:45 AM
Its like having a fuel/oil pressure gauge in the car..a necesary precaution. If you plan to run high boost that is..Other engines can run lean for quite a while, only displaying poor performance..higher tuned cars tend to go boom..
What exactly is the problem with your current setup? A wheel to steer the front of the car A pedal to steer the rear |
| DLI GZE no spark | 4agetercel | 5 | 8,713 |
02-01-2013 07:05 PM Last Post: 4agetercel |
| GZE Swop with PAS & AC | Lauren | 12 | 17,133 |
02-16-2012 01:04 PM Last Post: heshan |
| Engine sounds slush GZE with VIDEO ! | Okami | 13 | 18,097 |
01-03-2012 12:12 PM Last Post: Okami |
| GZE swap in a SR5 | TomTom15 | 3 | 5,650 |
11-04-2011 12:30 PM Last Post: MatthewG |
| GZE pulleys NEW question | Okami | 15 | 25,627 |
09-30-2011 07:08 PM Last Post: Lauren |
