Adding O2 sensor support
01-14-2011, 07:03 PM
It seems that the O2 output from the Innovate unit may be incorrect as I'm unable to get the unit working as it should. I suspect it is all wired into the ecu correctly but the afr's are so far out according to the LM2 that the ecu thinks the O2 sensor is faulty.
This is my 2nd Innovate LM2 the 1st one was replaced under warranty this one I will have to pay for repair, it has done less than one hours work An analogue brain in a digital World |
Radiator & grill support panel (Levin) | FanIsHere | 5 | 2,115 |
11-14-2022 10:07 PM Last Post: Ivan141 |
Lambda sensor wiring | sam3007 | 10 | 4,518 |
AE86 Engine Coolant Temp Sensor | izanagi | 8 | 20,395 |
Hall sensor | totta Crolla | 7 | 8,353 |
02-28-2014 10:07 AM Last Post: Ivan141 |
Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 11,048 |
10-25-2013 05:13 PM Last Post: Apsogos |
