Alu thick core radiator fitment
01-10-2022, 09:12 PM
Hi guys,
A few years ago 2014 I bought a thick core ae86 radiator here via the forum; it looks at least excactly like a Mishimoto one. After all those year, stored, I finaly want to install it Height and width look OK but, it is not a direct fit. As it seems, I need to extend the lower mounting points by 45-50mm due the thicker core. Is that a general issue with thicker core rads? or my bad luck? iff the botem would be 45-50 mm more inward, it would be a perfect fit, when I want to use the lower original mounts, i need to start cutting, and the rad would be tipped over to the back a bit. Regards, Roel Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
01-10-2022, 09:46 PM
It looks a lot like this one:
https://group-d.ie/products/ae86-alloy-r...4547417177 What happens when you put the bottom pins in first? Where does it interfere with the body? FABRICA MI DIEM, PVNC! |
01-10-2022, 10:27 PM
Looks like it yes.
it interferes as in the third picture, on the sides of the front frame left and right, and will interfere almost all the height. Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
01-10-2022, 11:09 PM
Best thing to do would be to find someone handy with a TIG welder in that case.. better to change the radiator than the chassis (with parts compatibility in mind).
If you read the comments on this youtube ad I found you'll see you're not the first one to run into problems with this radiator model: https://www.youtube.com/watch?v=hZy_3W_loxM FABRICA MI DIEM, PVNC! |
01-23-2022, 11:40 PM
ive cut the radiator fins to make it fit and worked like a charm
you can check the video here, its in spanish but its quite easy to follow, about 12:21 time mark https://www.youtube.com/watch?v=jDYfQp87...irokuSpain |
01-26-2022, 01:28 PM
(This post was last modified: 01-26-2022 01:50 PM by Gtsi-R.)
(01-23-2022 11:40 PM)AlexKTM Wrote: ive cut the radiator fins to make it fit and worked like a charmI actually cutted the fins myself too before seing the vid. did not wannted to modify the front of the car, it is now a tight, but is a fit! will most likely go for a spal fan. -no worries about the rusty top brackets, they are black again allready- anny experience on size do/dont tips? just want to replace it by a spal fan for the space claim, and bit better looks. =) Regards, Roel Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
Radiator & grill support panel (Levin) | FanIsHere | 5 | 2,110 |
11-14-2022 10:07 PM Last Post: Ivan141 |
AE86 F20C swap - Radiator issue | mad.matt | 3 | 5,973 |
02-07-2018 05:14 PM Last Post: mad.matt |
Radiator oem or upgrade on racecar? | Jimmi The Kid | 5 | 5,811 |
cool lower radiator hose | thanos | 4 | 5,476 |
bigger radiator for AE86? | Uzelac | 3 | 6,250 |
08-14-2015 07:08 PM Last Post: bozu |
