Alu thick core radiator fitment
01-10-2022, 09:12 PM
Hi guys,
A few years ago 2014 Wink I bought a thick core ae86 radiator here via the forum;
it looks at least excactly like a Mishimoto one.
After all those year, stored, I finaly want to install it
Height and width look OK but, it is not a direct fit.
As it seems, I need to extend the lower mounting points by 45-50mm due the thicker core. Is that a general issue with thicker core rads? or my bad luck?
iff the botem would be 45-50 mm more inward, it would be a perfect fit, when I want to use the lower original mounts, i need to start cutting, and the rad would be tipped over to the back a bit.
[Image: AEU86 AE86 - Alu thick core radiator fitment]
Regards, Roel
Gtsi-R
"Trust me, I was an engineer"
01-10-2022, 09:46 PM
It looks a lot like this one:
https://group-d.ie/products/ae86-alloy-r...4547417177
What happens when you put the bottom pins in first? Where does it interfere with the body?
01-10-2022, 10:27 PM
Looks like it yes.
it interferes as in the third picture, on the sides of the front frame left and right, and will interfere almost all the height.
Gtsi-R
01-10-2022, 11:09 PM
Best thing to do would be to find someone handy with a TIG welder in that case.. better to change the radiator than the chassis (with parts compatibility in mind).
If you read the comments on this youtube ad I found you'll see you're not the first one to run into problems with this radiator model:
https://www.youtube.com/watch?v=hZy_3W_loxM
01-23-2022, 11:40 PM
ive cut the radiator fins to make it fit and worked like a charm
you can check the video here, its in spanish but its quite easy to follow, about 12:21 time mark
https://www.youtube.com/watch?v=jDYfQp87...irokuSpain
01-26-2022, 01:28 PM (This post was last modified: 01-26-2022 01:50 PM by Gtsi-R.)
(01-23-2022 11:40 PM)AlexKTM Wrote:  ive cut the radiator fins to make it fit and worked like a charm
I actually cutted the fins myself too Smile before seing the vid. did not wannted to modify the front of the car, it is now a tight, but is a fit! will most likely go for a spal fan.
-no worries about the rusty top brackets, they are black again allready-
anny experience on size do/dont tips? just want to replace it by a spal fan for the space claim, and bit better looks. =)
Regards,
Roel
Gtsi-R
  Radiator & grill support panel (Levin) FanIsHere 5 2,060 11-14-2022 10:07 PM
  AE86 F20C swap - Radiator issue mad.matt 3 5,931 02-07-2018 05:14 PM
  Radiator oem or upgrade on racecar? Jimmi The Kid 5 5,708 06-23-2017 05:21 PM
Last Post: pack
  cool lower radiator hose thanos 4 5,400 11-29-2016 01:06 PM
Last Post: thanos
  bigger radiator for AE86? Uzelac 3 6,207 08-14-2015 07:08 PM
Last Post: bozu
