American Rally 86 UPDATE
08-20-2009, 11:50 PM
Post: #61
And some more. I made these little strengthener guys today
[Image: AEU86 AE86 - American Rally 86 UPDATE]
Excuse the crappy welds. I should have made them a bit longer, so they were kinda sitting recessed and didn't cooperate occasionally.
Wow, I could have sworn I had an account here... I guess I'm the new guy Sad
08-21-2009, 12:34 AM
Post: #62
n1 work. small tip. reinforce the 4 link connection points from the chassis. Good option it to connect them to the cage. because in a couple years it will show wear and tear because its a stress point.
08-21-2009, 12:51 AM
Post: #63
robokill Wrote:n1 work. small tip. reinforce the 4 link connection points from the chassis. Good option it to connect them to the cage. because in a couple years it will show wear and tear because its a stress point.
Thanks!
Yeah, I agree with reinforcing the mounts some more, I've been working on a way that doesnt involve more tube notching, hahaha, but I probably will hook it up to the cage. Definitely good advice!
08-21-2009, 01:48 AM
Post: #64
i see you've gotten well into using the bellmouth press tool Big Grin
once you stop with them its hard to get out1
and you copied my sill tubes Tongue
looks great dude.
Brake with the left hand, steer with the right foot...
08-21-2009, 02:27 AM
Post: #65
Fantastic build log, thanks for sharing it!
In my experience, the car invariably ends up navigator side down, and the driver falls on the navigator when he unclips his harness.
Guess who the navigator was......
08-21-2009, 04:06 PM
Post: #66
nice work,
i like the weldings i saw on some pictures.
http://bruutt.blogspot.nl/
08-22-2009, 06:37 AM
Post: #67
More little gusset progress. I made these to help strengthen the Upper A pillar corner
And this is the driver's side 4 link box so far.
I'll get stuff finished when it's done Big Grin hahaha Then I'll post more pics.
08-22-2009, 01:05 PM
Post: #68
how do u make these holes?
08-22-2009, 04:53 PM
Post: #69
Hi, I guess you are the same person who asked some questions on the British Rally Forum. I will assume for now....
Reading through your post I would say your suspension is too stiff, for gravel I run also a 40mm inverted front Bilstein but the rating is 300/70 springs are large diameter (i.e not 2.25") 190lb. On the back I have 140lb springs with Bilsteins, not sure of the rating though. Standard height front/rear. I have tried stiffer front springs but I keep going back to the 190's I would say you are somewhere between gravel and smooth tarmac at the moment.
Gearbox etc.
I have a Quaife Type 9 fitted and it has "rally" ratios 2.39 1st etc. should you decide to go the close ratio route you will definately need a lower final drive and I would say something like a 5.1-1 would be ideal.
You might want to try the standard 'box with a lower final drive, I think it would be a pretty good compromise.
As far as bellhousings go for the Type 9 the only one worth considering is one made by RM Sport and, as luck would have it there is one for sale on *bay (uk) at the moment. They are very difficult to source.
08-22-2009, 06:16 PM
Post: #70
the standard t50 is horrible on gravel, even with a 5.1...the 1st is much much too short, think 3.5:1! By the time you have gotten any power down you already need to change gears. Something with say a 2.3/2.4:1 then the next 4 gears are very close to that, is much more ideal Smile
  AE86 N2 (big update) 86Pilot 110 137,324 09-06-2013 11:33 AM
Last Post: Apsogos
  86er's Track rebuild N2.??? Finally an update page 8 86er 191 256,582 03-25-2012 10:05 AM
Last Post: bozu
  Supercharged Hachiroku "update" roadrunner 20 24,047 06-02-2011 03:27 AM
Last Post: kennedy8383
  AE86 two door 1987. in restoration, in Iceland UPDATE olithor 12 20,861 08-08-2009 12:36 PM
Last Post: rs1800
  AE86... update 25/06.. car might be for sale Eiwiss 57 65,225 08-01-2009 03:16 AM
Last Post: rymax86
