Another AE86, Duracell. Now with VEMS, and cage...
12-24-2011, 11:17 PM
Post: #41
Glad you like it .
Plate that goes to head is made on waterjet, if anyone need drawing let me know. I have both smallport and bigport, since I still can't decide which head to go with new cams |
12-24-2011, 11:29 PM
Post: #42
Have you planned anything to secure your ITB in place ?
Because I know that the vibrations of the engine can disconnect the ITB to the pipe, especially with a long one like yours. (one of my friend had that kind of problem with is FCR carb) |
12-25-2011, 12:05 AM
Post: #43
Will try with silicone hoses and clamps.
If not, than the welder will have to do |
12-25-2011, 02:21 PM
Post: #44
It look great
SR Team BURN THE RUBER NOT YOUR SOUL! |
12-29-2011, 12:11 PM
Post: #45
It was pain in the ass to weld 1.5mm wall tubing, but welder was skilled enought to pull of this:
Waiting for upper rings, will weld them soon. Then a bit of biax/dremel and to install it. Hope to feel the difference |
12-29-2011, 01:10 PM
Post: #46
Cool.
Buy Higrip silicone hoose and clamp SR Team BURN THE RUBER NOT YOUR SOUL! |
05-31-2012, 11:56 AM
Post: #47
Little update, just to show different, and definitive, route car is going:
11-13-2012, 11:48 AM
Post: #48
Been searching for a good header for months/years.
As I couldn't find we decided to do one: Made of 40mm (37mm Id) stainless T304 pipes with mandrel bent tubes. Friend is a skillful velder: 40mm tubing (37mm ID) / Slip on collector / 4-1 design / 700mm runner lenght In place: Hope it won't be colorless too long Collector output is not finished, not sure if i should run 55/60 or 63mm. I'm closest to 60mm.. Does anyone know, why some headers have restriction cone after collector and than they go back to standard exhaust diameter ? Think they call it taper. Should i try with that option ? Maybe 40->60 (collector) -> cone to 55mm -> cone back to 60.5mm ? Thanks |
11-13-2012, 12:27 PM
Post: #49
Just... WOW!
11-13-2012, 02:07 PM
Post: #50
Thanks
btw. next stop: |
AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides | Conrad | 462 | 603,459 |
AE86 from Portugal (restoring gearbox now...) | Homem Bomba | 13 | 22,717 |
01-01-2013 11:45 PM Last Post: Homem Bomba |
Levin Coupe from Croatia - NOW SR86 with IRS | ZaX | 698 | 710,351 |
10-01-2012 08:07 PM Last Post: ZaX |
project "twin cam 16" another AE86... | fax0815 | 11 | 17,890 |
11-19-2011 09:05 AM Last Post: BOOMEX |
Doc's KE20: - really coming together now | The Doctor | 548 | 510,040 |
08-03-2011 11:57 AM Last Post: The Doctor |
