Another AE86, Duracell. Now with VEMS, and cage...
12-24-2011, 11:17 PM
Post: #41
Glad you like it Smile.
Plate that goes to head is made on waterjet, if anyone need drawing let me know.
I have both smallport and bigport, since I still can't decide which head to go with new cams Smile
12-24-2011, 11:29 PM
Post: #42
Have you planned anything to secure your ITB in place ?
Because I know that the vibrations of the engine can disconnect the ITB to the pipe, especially with a long one like yours.
(one of my friend had that kind of problem with is FCR carb)
12-25-2011, 12:05 AM
Post: #43
Will try with silicone hoses and clamps.
If not, than the welder will have to do Big Grin
12-25-2011, 02:21 PM
Post: #44
It look great Wink
SR Team
BURN THE RUBER NOT YOUR SOUL!
12-29-2011, 12:11 PM
Post: #45
It was pain in the ass to weld 1.5mm wall tubing, but welder was skilled enought to pull of this:
[Image: AEU86 AE86 - Another AE86, Duracell. Now...nd cage...]
Waiting for upper rings, will weld them soon.
Then a bit of biax/dremel and to install it. Hope to feel the difference Big Grin
12-29-2011, 01:10 PM
Post: #46
Cool.
Buy Higrip silicone hoose and clamp Wink
SR Team
05-31-2012, 11:56 AM
Post: #47
Little update, just to show different, and definitive, route car is going:
11-13-2012, 11:48 AM
Post: #48
Been searching for a good header for months/years.
As I couldn't find we decided to do one:
Made of 40mm (37mm Id) stainless T304 pipes with mandrel bent tubes.
Friend is a skillful velder:
40mm tubing (37mm ID) / Slip on collector / 4-1 design / 700mm runner lenght
In place:
Hope it won't be colorless too long Smile
Collector output is not finished, not sure if i should run 55/60 or 63mm.
I'm closest to 60mm..
Does anyone know, why some headers have restriction cone after collector and than they go back to standard exhaust diameter ?
Think they call it taper.
Should i try with that option ? Maybe 40->60 (collector) -> cone to 55mm -> cone back to 60.5mm ?
Thanks
11-13-2012, 12:27 PM
Post: #49
Just... WOW! Respect! Respect!
11-13-2012, 02:07 PM
Post: #50
Thanks Smile
btw. next stop:
  AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides Conrad 462 617,734 06-27-2017 12:21 PM
Last Post: DJexor
  AE86 from Portugal (restoring gearbox now...) Homem Bomba 13 23,303 01-01-2013 11:45 PM
Last Post: Homem Bomba
  Levin Coupe from Croatia - NOW SR86 with IRS ZaX 698 752,391 10-01-2012 08:07 PM
  project "twin cam 16" another AE86... fax0815 11 18,331 11-19-2011 09:05 AM
Last Post: BOOMEX
  Doc's KE20: - really coming together now The Doctor 548 531,987 08-03-2011 11:57 AM
Last Post: The Doctor
