Brake problems
10-23-2006, 05:53 PM
Brake problems
I was changing my brakepads on the rear and half way i run stuck...
the space between the brakepiston and brakecaliper arms (A on foto) is smaller than the brakepads + brakedisk (B).
I've turned the piston to the max than it fits but the deep surface on the piston is not at the good place. Doesn't match the higher surface on the pads, so I had to turn it a bit anti-clockwise. After that size A is to small...
Help me please! I don't know what to do Sad
[Image: AEU86 AE86 - Brake problems]
10-23-2006, 06:02 PM
Brake problems
it should fit about flush with the surface behind it, if it stops turning earlier then your handbrake mechanism is getting bad (mine is really bad..)
Use more force and try to turn it in further..
10-23-2006, 06:11 PM
Brake problems
ivan: Do you have the tool for turning the piston? I use a (waterpomptang) but can't use more force to turn the piston.
Do you think i have to loosen the handbrake?
10-23-2006, 06:20 PM
Brake problems
In the worst case you can take a flat sheet of sanding paper and sand the pad down until it fits.
10-23-2006, 06:23 PM
Brake problems
take the cap off the reservoir. turn piston to full extent clockwise then one quarter back or until the recesses are in line, thats the brakes set, if the pads wont fit in as happens on my car, shave a little of the face of the pad bout a mm and it`ll slip in. it takes a bit of practice but you can get it flat if you try. it does lower the life of the pad a tiny bit, but at least they fit.
removing the handbrake can help, but it can be a bugger to refit so i never bother, as the handbrakes on AE86`s are just crap!!!!
Its gotta go whoosh or give a whine!!!!
10-23-2006, 09:04 PM
Brake problems
thanks guys! I think I need to shave the brakepads a little, because it won't fit. is it a problem if i let the shims out? it saves me 1 mm extra shaving....
10-23-2006, 09:15 PM
Brake problems
Should not be a problem they're just to avoid squeeling. I don't have any shims on my EE80 front brakes as well. And I left them off only after discussing that with my local garage guy.
10-24-2006, 10:47 AM
Brake problems
Better rebuild calipers. Or at least change the brake fluid...
10-24-2006, 11:04 AM
Brake problems
jamiemirror Wrote:Better rebuild calipers. Or at least change the brake fluid...
Those are both very good ideas of course :-)
10-24-2006, 11:06 AM
Brake problems
Won't help if its the handbrake mechanism..:-(
  Big wheel problems gh0st 16 12,142 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 3,987 08-31-2021 06:20 PM
Last Post: totta Crolla
  Problems Mintex M1155 pads Dino86 9 11,186 07-04-2017 11:22 AM
  16v Bigport fuel problems Rascal21 1 5,780 07-04-2015 01:00 AM
Last Post: jondee86
  Starter problems Widar 49 138,734 02-09-2015 10:11 AM
