Brake woes
09-23-2011, 05:56 PM
Brake woes
There appear to be at least two different types of brake booster fitted to the AE86
The two different ones I know of have a different fitting for the master cylinder, one has the two studs level the other has the studs at about 30 degrees to each other.
Can anyone tell me if the two are interchangable please. (apart from the master cylinder fitting being different)
09-24-2011, 11:29 AM
Brake woes
I thought I would just put a repair kit into the old master cylinder until I found out the price of the kit from Toyota.
£92.17 Confused
09-24-2011, 12:14 PM
Brake woes
There are other that will fit but dont quote me, or go pedal box for competition car? these are ok but require remote resevoirs,
http://www.grp4fabrications.com/product_...cts_id=365
09-24-2011, 02:33 PM
Brake woes
thanks for the link, I will definately look into it Thumbs up!
09-25-2011, 10:18 AM
Brake woes
There is another one with 4 bolts fitted to some of the kouki models
Ignore the filth, it's hard to keep clean around here with all the sand.
[Image: AEU86 AE86 - Brake woes]
AE86 ex-daily
09-25-2011, 10:40 AM
Brake woes
Ive heard that Hilux + other fit & have the same stroke.
R32 skyline non-abs also fits but you need to modify your lines as the nissan are rear-front left-front right as in 3 hoses off the master cylinder.
If you do go for the pedal box there is a bit of work involved + remove the clutch pedal first to make life easier.
09-26-2011, 11:21 AM
Brake woes
I think the pedal box thing may have to wait as I have a rally in a couple of weeks but by all accounts it is a mod. worth doing.
Just been offered a 4 bolt servo / master cylinder combo like the one pictured by Bean Bandit, I wonder how common they are and would it be more rigid than the 2 bolt one ?
09-26-2011, 12:09 PM
Brake woes
If its a road legal car you wont be able to get an MOT on a car with a pedal box as the booster would need to be removed. Unless you go to a "friendly" mot centre that is willing to overlook it.
My Hachi Roku
09-27-2011, 12:08 PM
Brake woes
I wonder if Toyota standardised the brake servo's later on as the 4
bolt one looks very similar to the AW11 MR2 MK1b one.
If so could the AW11 master cylinder be used ??
Oh and the 4 bolt fitting thing ?
I reckon it is because the later master cylinder is made from steel rather than alloy and it weighs a ton by comparison ! A lot of weight to hang on just 2 studs.
10-31-2011, 10:46 AM
Brake woes
Bump. My brake booster seems to be failing as well (randomly) and need to find a solution ASAP. Thanks! Thumbs up!
  Brake master cylinder for FC3S brake conversion Hachi Go 8 14,078 03-03-2011 12:06 AM
Last Post: filh
  Oil cooler woes hachirokuGTV 14 11,984 04-17-2008 01:49 AM
Last Post: 4agze
  Handbrake woes totta Crolla 21 22,892 04-14-2008 03:28 PM
Last Post: Dr.Ling
  How to bleed brake system after master brake replacement Ivan141 12 18,994 09-18-2005 11:21 PM
