Burning oil?
03-17-2008, 02:27 PM
Burning oil?
I have noticed lately that my car uses a lot of oil, and i do mean A LOT. After 1000km the engine is almost empty? Any ideas on what this could be, i have no oil leaks and there is no blue smoke from tailpipe?
Could this be the end of the engine Sad , it does have 250k+ on it so wouldn't be surprised. But if it was near the end it wouldn't feel this strong?
Any info would be appreciated Thumbs up!
No Smorking AE86
03-17-2008, 02:38 PM
Burning oil?
I think that the problem is youre pistonrings en oil scrapers..
I had that problem with the AE101..
so time for an other engine?
03-17-2008, 09:34 PM
Burning oil?
rice burner, haha Tongue
the old 4age gunas burn off some oil with that mileage, 4 sure!
i had a ae92, with a 4age and it had 170,000 miles on it, and it drank loads of oil, and i didnt see any blue smoke.
but yea id say rings, r on the way out.
[Image: AEU86 AE86 - Burning oil?]
03-18-2008, 10:28 AM
Burning oil?
Driving style ? Drifting or not ? Hi-revving or not ? Smoke ?
03-19-2008, 11:18 PM
Burning oil?
Pistons rings or valve seals are the most probable root causes...
Keeping the AE86 alive!
03-21-2008, 02:36 PM
Burning oil?
jamiemirror Wrote:Driving style ? Drifting or not ? Hi-revving or not ? Smoke ?
No drifting, some high revving but not all the time and there is no smoke from the rear, i just think the engine had it's best time but as long as it runs i'll let it be, it just needs to last me a year so i'll take it easy. After then it'll be registered as oldtimer and then the engine will go in the bin and be replaced with something different Evil
No Smorking AE86
03-21-2008, 02:46 PM
Burning oil?
Replace valve seals, then if problem stil persist - piston rings.
03-21-2008, 04:12 PM
Burning oil?
oil leak?
03-21-2008, 07:13 PM
Burning oil?
No i checked there are no oil leaks what so ever, not a drop. It's just old age i guess, i'll see what i will do. For now i will just keep driving. I don't use it often (i got it a year and just reached 5000km) so i hope it'll hold another year.
Thanks to all for the info Thumbs up!
No Smorking AE86
  trans oil, lsd oil change Apolan 9 22,239 10-01-2014 03:57 PM
  Oil cooler -> low oil pressure Jan Pedersen 24 40,396 06-06-2013 07:36 PM
Last Post: Deuce Cam
  4AGE crankcase gas and oil pressure too high, sprinking oil demogun 5 10,923 10-01-2011 09:47 AM
Last Post: demogun
  Silvertop burning oil - compression results Jezza_hr 3 6,513 10-18-2008 02:51 AM
Last Post: jondee86
  Oil Presure and what oil i have to use? CHACAMAN 4 7,886 08-27-2008 05:35 AM
Last Post: F0Bman
