Burning oil?
03-17-2008, 02:27 PM
Burning oil?
I have noticed lately that my car uses a lot of oil, and i do mean A LOT. After 1000km the engine is almost empty? Any ideas on what this could be, i have no oil leaks and there is no blue smoke from tailpipe?
Could this be the end of the engine , it does have 250k+ on it so wouldn't be surprised. But if it was near the end it wouldn't feel this strong? Any info would be appreciated No Smorking AE86 |
03-17-2008, 02:38 PM
Burning oil?
I think that the problem is youre pistonrings en oil scrapers..
I had that problem with the AE101.. so time for an other engine? |
03-17-2008, 09:34 PM
Burning oil?
rice burner, haha
the old 4age gunas burn off some oil with that mileage, 4 sure! i had a ae92, with a 4age and it had 170,000 miles on it, and it drank loads of oil, and i didnt see any blue smoke. but yea id say rings, r on the way out. |
03-18-2008, 10:28 AM
Burning oil?
Driving style ? Drifting or not ? Hi-revving or not ? Smoke ?
03-19-2008, 11:18 PM
Burning oil?
Pistons rings or valve seals are the most probable root causes...
Keeping the AE86 alive! |
03-21-2008, 02:36 PM
Burning oil?
jamiemirror Wrote:Driving style ? Drifting or not ? Hi-revving or not ? Smoke ? No drifting, some high revving but not all the time and there is no smoke from the rear, i just think the engine had it's best time but as long as it runs i'll let it be, it just needs to last me a year so i'll take it easy. After then it'll be registered as oldtimer and then the engine will go in the bin and be replaced with something different No Smorking AE86 |
03-21-2008, 02:46 PM
Burning oil?
Replace valve seals, then if problem stil persist - piston rings.
03-21-2008, 04:12 PM
Burning oil?
oil leak?
03-21-2008, 07:13 PM
Burning oil?
No i checked there are no oil leaks what so ever, not a drop. It's just old age i guess, i'll see what i will do. For now i will just keep driving. I don't use it often (i got it a year and just reached 5000km) so i hope it'll hold another year.
Thanks to all for the info No Smorking AE86 |
trans oil, lsd oil change | Apolan | 9 | 16,944 |
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 30,082 |
4AGE crankcase gas and oil pressure too high, sprinking oil | demogun | 5 | 7,673 |
Silvertop burning oil - compression results | Jezza_hr | 3 | 4,639 |
10-18-2008 02:51 AM Last Post: jondee86 |
Oil Presure and what oil i have to use? | CHACAMAN | 4 | 5,333 |
08-27-2008 05:35 AM Last Post: F0Bman |
