Cams /w 9+mm Lift
08-25-2008, 08:15 PM
Cams /w 9+mm Lift
Hi,
Where can I find Hi-lift cams (9mm+) for the 16V engine? Duration about 260-270° (a little more aggressive than the KK101 from Ted Components) -> What about Toda cams? 264/272° @ 9/10mm Are Toda valve springs ok for >9mm lift? Combined with 1SZ-FE buckets Thanks, Patrick |
08-25-2008, 09:25 PM
Cams /w 9+mm Lift
toda says that their valve springs are o.k. up to 10.5mm lift.
go-go-go! |
08-26-2008, 12:41 PM
Cams /w 9+mm Lift
ok, that's already useful info, thanks!
08-27-2008, 05:31 AM
Cams /w 9+mm Lift
That is a good amount of lift, you might need under bucket shims.
08-27-2008, 08:14 AM
Cams /w 9+mm Lift
Well, thats what I wrote....
08-27-2008, 09:14 PM
Cams /w 9+mm Lift
CAT CAMS
Here: http://www.catcams.be/800x600/mainframe.htm?english and pricing here: http://www.catcams.co.uk/pricing.asp An analogue brain in a digital World |
09-10-2008, 08:52 AM
Cams /w 9+mm Lift
i ll use 272 and 10,3lift. ll i need shims?
**COROLLA EE80 - 4AGE 124HP** |
09-10-2008, 07:08 PM
Cams /w 9+mm Lift
You should consider TODA cams or HKS cams. They are readily available and have sizes you need.
09-10-2008, 11:29 PM
Cams /w 9+mm Lift
i have bought TODA with that duration and lift
Shim size for AM cams | kazi | 4 | 5,129 |
Toda Cams | Alex170984 | 7 | 8,468 |
02-11-2017 05:50 PM Last Post: Alex170984 |
20V cams - CATCAMS vs KELFORD? | Grant | 19 | 38,445 |
11-19-2015 07:45 AM Last Post: hachirokkos |
Effects of valve lift - worth it going higher? | harkes | 18 | 16,602 |
03-17-2014 09:21 PM Last Post: oldeskewltoy |
Max lift on Vitz valve lifters | harkes | 9 | 10,913 |
01-02-2014 10:27 AM Last Post: Bean |
