Car hesitates between 2500-2800 rpm
11-18-2012, 09:25 PM
For a 4AGE with EFI, the ignition timing advance is controlled by the ECU
according to a factory programmed map. The distributor provides rpm
and crank angle information only. If the engine starts and runs with no
obvious problems, then it is safe to assume that both the ignition map in
the ECU and the distributor function are OK.
Cheers... jondee86
11-18-2012, 09:39 PM
max_ae86 Wrote:1) I didn't. Going step by step. Other distributor still needs to be fixed (seal leakage) so I need time to finish it.
2) I will, maybe tomorrow.
3) Maybe not, but you never know with 25 old wires.
You can check it with leaking distributor, maybe problem is not there
  No idle below 2000 rpm rich running Steller Engineering 3 1,491 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 6,828 07-31-2019 11:28 AM
  Bad vibrations /resonance starts at 5000 rpm izanagi 7 8,346 07-23-2015 05:02 PM
  Decently heavy vibration in fourth gear between 2000-2300rpm dinkers542 4 5,573 11-29-2014 12:27 AM
Last Post: dinkers542
  Engine Check Light at High RPM Super86 8 8,663 11-03-2014 11:03 AM
Last Post: Super86
