Car hesitates between 2500-2800 rpm
11-18-2012, 09:25 PM
For a 4AGE with EFI, the ignition timing advance is controlled by the ECU
according to a factory programmed map. The distributor provides rpm and crank angle information only. If the engine starts and runs with no obvious problems, then it is safe to assume that both the ignition map in the ECU and the distributor function are OK. Cheers... jondee86 |
11-18-2012, 09:39 PM
max_ae86 Wrote:1) I didn't. Going step by step. Other distributor still needs to be fixed (seal leakage) so I need time to finish it. You can check it with leaking distributor, maybe problem is not there |
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,442 |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 6,739 |
Bad vibrations /resonance starts at 5000 rpm | izanagi | 7 | 8,285 |
07-23-2015 05:02 PM Last Post: Bean |
Decently heavy vibration in fourth gear between 2000-2300rpm | dinkers542 | 4 | 5,521 |
11-29-2014 12:27 AM Last Post: dinkers542 |
Engine Check Light at High RPM | Super86 | 8 | 8,594 |
11-03-2014 11:03 AM Last Post: Super86 |
