Car hesitates between 2500-2800 rpm
11-17-2012, 03:18 PM
ZDoman Wrote:if the EGR system is not working, and your air intake or exhaust system is not original then its a common thing on AFM engines, because the EGR is recirculating some unburtn exhaust gases at this point, which can occur in lean mixture when not-working..
I removed rusty EGR long time ago Smile
Fun is not the straight line!
11-17-2012, 03:22 PM
jondee86 Wrote:Checked your ignition timing recently ?
Cheers... jondee86
Checked yesterday, it was almost at zero, so I pushed it back to 10 (with check connector shortened).
11-17-2012, 03:28 PM
So what I did:
1) Grounded AFM body with extra wire.
2) Put timing back to 10
Went for a short ride, car runs smoother and haven't noticed any hesitation. I will continue to follow this up.
11-17-2012, 06:53 PM
I suggest You check ignition timing from 2000 to 3500 rpm
11-17-2012, 07:06 PM
jonis79 Wrote:I suggest You check ignition timing from 2000 to 3500 rpm
I have timing light but I don't understand what you mean:
Do you mean without check connector shortened?
Which advance should be there between 2000-3500?
11-18-2012, 05:24 AM
max_ae86 Wrote:So what I did:
AFM body does not need to be grounded. All the necessary grounds (ECU
and FP switch) are provided in the plug. Being 10 deg retarded would
probably get your exhaust really hot, as well as losing a lot of power. You
should feel better pickup now Smile
Cheers... jondee86
11-18-2012, 06:26 PM
1. Do you checked problem with other distributor?
2. Check timing on 2000, 2200, 2400, 2600, 2800 and 3000 rpm and write what you got.
3. Its not ground problem.
11-18-2012, 07:30 PM
jonis79 Wrote:1. Do you checked problem with other distributor?
The timing will change as to whether the engine is under load or not
and also by how much load there is, so the obvious question is
how is he going to check it and at which load point ?
11-18-2012, 08:11 PM
check without load on hot engine, you will see how timing depending on the rpm.
11-18-2012, 09:24 PM
1) I didn't. Going step by step. Other distributor still needs to be fixed (seal leakage) so I need time to finish it.
2) I will, maybe tomorrow.
3) Maybe not, but you never know with 25 old wires.
  No idle below 2000 rpm rich running Steller Engineering 3 1,443 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 6,742 07-31-2019 11:28 AM
  Bad vibrations /resonance starts at 5000 rpm izanagi 7 8,285 07-23-2015 05:02 PM
  Decently heavy vibration in fourth gear between 2000-2300rpm dinkers542 4 5,521 11-29-2014 12:27 AM
Last Post: dinkers542
  Engine Check Light at High RPM Super86 8 8,594 11-03-2014 11:03 AM
Last Post: Super86
User(s) browsing this thread: 16 Guest(s)
