Car shuts off while driving!?
12-28-2008, 05:50 PM
Hi everyone, I have an 85 gts with an extremely abnormal problem, and Im desperate for help. After driving for a bit I will be accelerating and while on the gas the power will completely cut out for 1 or 2 seconds then jut back in again and cut off again until I ease off the gas. I first noticed this while taking corners but later realized it also happens while accelerating on straightaways. However it only happens while I'm on the gas fairly hard or floored, and If I go get gas the problem disappears for a while, and it seems that the lower the fuel gage reads the more severe the problem gets so for now I've been filling up when the fuel gauge gets down to 3/4 or so. Also it only does it when the car has thoroughly warmed or when driven with a good amount of enthusiasm otherwise the car only has 66,000 miles and the engine runs excellent when its not experiencing this problem. Any help would be appreciated.
12-28-2008, 09:03 PM
So it sounds like a fuel problem then
![]() could be pump, filter or the regulator on the fuel rail. I would be tempted to change the filter first. An analogue brain in a digital World |
12-28-2008, 09:49 PM
There is a pipe inside the gas tank which I think is clogged.
Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
12-29-2008, 01:01 AM
Thanks for all the help guys, Ill definitely look into everything you guys mentioned.
20V blacktop. what kind off ecu??? | slowboy2 | 11 | 14,417 |
07-17-2015 07:01 PM Last Post: jdm86gtz |
Car shutting off and ECU making noise | rawb_dbap | 8 | 8,090 |
05-03-2013 11:51 PM Last Post: rawb_dbap |
crankshaft timing belt pulley won't come off | Dino86 | 8 | 9,807 |
02-21-2011 02:05 PM Last Post: Project D |
Broke off the key in the ignition. | Aram | 5 | 5,214 |
10-29-2010 04:38 PM Last Post: Aram |
Driving help | halu_aoi | 6 | 6,328 |
06-26-2010 12:03 AM Last Post: halu_aoi |
