Carb conversion but what is this and how ?
03-14-2016, 10:38 PM
Well the reason for this post is this
http://www.86garage.com/blog/archives/220 Check the distributor further down. Using a sr20 distributor and cop setup. Really interesting! Because I am trying to find a solution when blocking the distributor port and have a cop setup with a msd system I stumbled upon this. Is the signal usable with msd computer ? And can i even get this adapter needed ? Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
03-15-2016, 12:06 AM
Actually I found that part possible to buy from cby directly, my japanese skills are not dull yet,
http://www.cby.jp/hachiroku/parts.html this adapter is way overpriced 450euros no one can make one of these in europe ? ![]() ![]() Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
03-15-2016, 10:32 AM
Oda's setup is NOT a carburator but an Hayabusa ITB (fuel injected)
![]() (and it's not a SR20 distributor but an SR20 cam angle sensor + RB coils) You can convert your original distributor in a CAS only if you want: http://www.sq-engineering.com/20v-4age-d...r-302.html and for the coil on plug part, you will need a proper ECU. |
03-15-2016, 03:26 PM
Or use 4agze cas distributor.
I happen to have one for sale ![]() ![]() |
03-15-2016, 08:08 PM
I'll be using a SR20DET CAS on my build powered with my Haltech. Is it necessary? No. I have a 4AGE 24+2 distributor which can be used just as well with little modification. If an MSD can run it I can't tell as I don't know enough about MSD gear.
AE86 ex-daily |
05-24-2016, 08:48 AM
(03-15-2016 03:26 PM)ditn Wrote: Or use 4agze cas distributor. Do you still have it? Im interested ![]() Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
20v Blacktop conversion.... | Mylesmck | 0 | 594 |
04-29-2024 05:48 PM Last Post: Mylesmck |
Kouki to Zenki Levin grill conversion? | Mylesmck | 6 | 2,696 |
02-08-2024 10:30 AM Last Post: r.ave |
AFM to Map Conversion | ps13michi | 3 | 3,616 |
Engine starts/revs but no idle | GenkiMotors | 17 | 8,101 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
Sub panel and rotary-button replacement for Levin -> Trueno conversion | gh0st | 9 | 6,033 |
11-05-2021 08:17 PM Last Post: gh0st |
