Carina rear end questiom
08-28-2008, 02:44 PM
Hellod!!!
Anyone knows if the toyota carina st (ta40) rear axle is the same as the toyota ae86, or if the lsd of a ae86 will fit the diff??. Has the carins diff disc brakes?? Thanks Always on top always on sideways http://img512.imageshack.us/img512/6080/...tomrx5.jpg |
09-03-2008, 05:38 AM
If not, I heard that the AE86, rear end can be used on the Carina.
09-04-2008, 04:31 PM
Axle should be the same since ta40 axle is the same as ta60 axle, but it uses drum breaks. However I think the mounting points are different. Perhaps you can ask Brawnie: he just sold his AE86 with Carina axle.
1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
09-04-2008, 04:54 PM
Zenki AE86 diffs wil fit the TA12/TA22/TA40/TA60 solid rear ends, but you need to take off 6mm of the halfshafts to get it to accept an LSD
![]() "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
09-04-2008, 10:32 PM
The Doctor Wrote:Zenki AE86 diffs wil fit the TA12/TA22/TA40/TA60 solid rear ends, but you need to take off 6mm of the halfshafts to get it to accept an LSDThat's good info! ![]() Anyone got a zenki diff lying around for me somewhere? ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
09-05-2008, 09:03 PM
problem solved many
![]() ![]() Always on top always on sideways http://img512.imageshack.us/img512/6080/...tomrx5.jpg |
04-15-2011, 02:57 PM
Sorry for reviving dead thread, but I was just wondering if this is dead certain before I go nuts with 4age/2tg build, T50 tranny, dw coilovers and equip a zenki ae86 lsd and rear ae86 brakes+pedal box w/adjustable bias, spacers and the whole package for my TA40 wagon: a Zenki ae86 LSD of ANY brand (TRD, Tomei, Kaaz, etc) will definitely fit solid TA40 rear axle? Or did Topic Starter find a different solution?
Regards R21 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
04-16-2011, 08:11 PM
Yes , any zenki will fit, you can doublecheck the VIN-tag on the firewall, look at Trans/axle it should say T50 T(3 numbers) The "T" is telling you it will fit and the number will tell you the ration and that its an open diff!
Remember that if you use a Toyota diff the axles need to be shortened, this might also apply to other brands... 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
05-08-2011, 04:06 PM
Ah ok, it`s a T312 axle. (T40 transmission)
I`ll get a zenki TRD ae86 LSD then. Might also have to look at getting discs rear, the right rear drum is shot ![]() Thanks for a conclusive answer! 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
Carina TA63 GT-TR - Suspension?? | danny 86 | 11 | 10,086 |
01-30-2021 03:39 PM Last Post: danny 86 |
Carina drivers! - Coilovers for a TA60/62 | nyberrg | 2 | 7,006 |
06-05-2017 10:03 AM Last Post: nyberrg |
20v mains & big end bearing | izanagi | 9 | 11,476 |
12-26-2016 12:42 PM Last Post: pack |
TA60/TA62 Carina; what fits? | nyberrg | 10 | 17,646 |
10-12-2016 12:57 PM Last Post: The Doctor |
Ta60 carina steering upgrade? | Allexz | 15 | 17,551 |
06-01-2016 08:12 AM Last Post: Allexz |
