Check Engine Light Flashes While Driving
08-09-2007, 07:16 AM
I just converted my car to a japanese MAP setup. Car runs fine except for some weird noises. In addition, while driving, the check engine light blinks on and stays on for 1-2 seconds and turns off. There is no decrease in engine performance or sound. It just blinks and goes off. I do notice that it flashes more frequently when going up and incline. It also happens while driving on level ground so I am not sure what is going on. I checked for engine codes; everything checked out normal. What can this be?
08-15-2007, 09:03 AM
does this mean a lean condition? I'll give you a TRUENO decal if you give me some insight.
08-16-2007, 08:15 AM
It looks like the Check Engine light is switched to earth by the ECU,
so make sure you don't have an intermittent short to earth in the wire
between the dash cluster and the ECU.
Cheers... jondee86
08-16-2007, 11:23 AM
When I come home tonight I have the error log of the ECU. I can read out the error code for you.
08-18-2007, 06:27 PM
Thanks guy, I have the manual with all the codes. When I short the connector, it does not flash any codes. I'll check my wiring one more time. I really doubt I have an earth wire short. This only happens when I go up a hill, perhaps there is some wiring around the gas pedal shorting out when I give more gas? Light doesn't come on at WOT.
08-18-2007, 06:41 PM
Ground for the ECU contains some 7-8 wires... It goes from ECU conector (on the passanger side) to the intake manifold UNDER the injector harnes... Wink
Check if that is conected well
If you don't get any results from it, make a T conector on one of the vacums on the manifold and put a ordinary boost gauge and check at hat vacuum does the light go on... But I don't think that is of an issue here...
Good luck
Smile
SNO-MO-BIRU project started- CHIRO
  Engine Check Light at High RPM Super86 8 9,003 11-03-2014 11:03 AM
Last Post: Super86
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 8,395 10-30-2013 11:18 PM
  engine start up and retractor light kawo 12 18,582 10-13-2013 02:23 PM
Last Post: pack
  Check battery light goes ON MartinS 23 22,995 02-14-2012 11:03 AM
Last Post: jondee86
  left turn signal always flashes. bulbs are good Mitchen 1 3,275 07-27-2010 12:33 AM
Last Post: Mitchen
