Checking ring gear diff
07-07-2014, 08:51 AM
Hi all.
Is the Toyota FSM method to check the ring diff is the best or is there any other method to check it ?
Envoyé depuis mon GT-I9100 avec Tapatalk
07-07-2014, 01:31 PM
Plenty of generic Toyota info here:
http://www.gearinstalls.com/
and the info as above could be used in conjunction with the FSM
Why are you wanting to check it ?
07-07-2014, 02:05 PM
(07-07-2014 01:31 PM)totta Crolla Wrote:  Plenty of generic Toyota info here:
Because my diff is still whining after changing my bearings so i guessed that was my ring who was bad but after checking with the Toyota method is appears that my ring is in good condition.
So i would like to be really sure before buying a new cwp kit.
07-09-2014, 07:38 AM
How bad is the whine ? Do pedestrians look round expecting
to see a fire engine as you approach ? If the gears look good
(no excessive wear or pitting) and the contact patch and
backlash have been set correctly, then the noise is annoying,
but not a sign that the diff is going to fail. Try using a heavier
weight specialist diff oil. Sometimes that will reduce the noise,
and sometimes the noise will improve as the parts wear into
eack other. So give the car some good hard driving Smile
Cheers... jondee86
  5th gear issue r.ave 1 2,540 03-14-2021 08:52 PM
  ring gear bolts DJexor 3 5,401 12-26-2016 10:56 PM
Last Post: totta Crolla
  T50 gearbox - TRD 2nd and 3rd gear hachirokkos 3 6,584 11-27-2015 10:06 AM
Last Post: Project D
  Decently heavy vibration in fourth gear between 2000-2300rpm dinkers542 4 5,499 11-29-2014 12:27 AM
Last Post: dinkers542
  Ring & pinion ratio. izanagi 27 27,169 07-05-2014 07:35 PM
Last Post: assassin10000
