Checking ring gear diff
07-07-2014, 08:51 AM
Hi all.
Is the Toyota FSM method to check the ring diff is the best or is there any other method to check it ? Envoyé depuis mon GT-I9100 avec Tapatalk |
07-07-2014, 01:31 PM
Plenty of generic Toyota info here:
http://www.gearinstalls.com/ and the info as above could be used in conjunction with the FSM Why are you wanting to check it ? An analogue brain in a digital World |
07-07-2014, 02:05 PM
(07-07-2014 01:31 PM)totta Crolla Wrote: Plenty of generic Toyota info here: Because my diff is still whining after changing my bearings so i guessed that was my ring who was bad but after checking with the Toyota method is appears that my ring is in good condition. So i would like to be really sure before buying a new cwp kit. Envoyé depuis mon GT-I9100 avec Tapatalk |
07-09-2014, 07:38 AM
How bad is the whine ? Do pedestrians look round expecting
to see a fire engine as you approach ? If the gears look good (no excessive wear or pitting) and the contact patch and backlash have been set correctly, then the noise is annoying, but not a sign that the diff is going to fail. Try using a heavier weight specialist diff oil. Sometimes that will reduce the noise, and sometimes the noise will improve as the parts wear into eack other. So give the car some good hard driving Cheers... jondee86 |
5th gear issue | r.ave | 1 | 2,540 |
03-14-2021 08:52 PM Last Post: Ivan141 |
ring gear bolts | DJexor | 3 | 5,401 |
12-26-2016 10:56 PM Last Post: totta Crolla |
T50 gearbox - TRD 2nd and 3rd gear | hachirokkos | 3 | 6,584 |
Decently heavy vibration in fourth gear between 2000-2300rpm | dinkers542 | 4 | 5,499 |
11-29-2014 12:27 AM Last Post: dinkers542 |
Ring & pinion ratio. | izanagi | 27 | 27,169 |
07-05-2014 07:35 PM Last Post: assassin10000 |
