07-31-2006, 10:28 PM
Post: #291
Your new exhaust looks very nice! How much was it if you don't mind me asking
Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
07-31-2006, 10:39 PM
Post: #292
Header 250€
Apexi WS Universal Muffler 150€ 2 1/4" Pipe and mid muffler 300€ (a lot more than I initially expected because I made a lot of wrong decisions) |
07-31-2006, 10:46 PM
Post: #293
Looks good.
The exchaust sits very close to the propshaft and rearaxel.. Doesnt it hit when you turn or with heavy load in the car? Youtube Myspace and I´ll Google your Yahoo |
07-31-2006, 10:47 PM
Post: #294
nice exhaust. does de sound like this? http://members.cox.net/teamintegra2/apexiws.mp3
07-31-2006, 11:19 PM
Post: #295
It looks that it's close to the prop shaft and rear axle, but it isn't. The nearest is 5-7cm, and the rear axle doesn't play that much. I've tested the car with 4 people inside, going in a bumpy road and i had no problem whatsoever.
oldskull the sound isn't so deep. It's a little more metallic. I'll try to record it soon! Best regards |
08-01-2006, 02:03 PM
Post: #296
why didn't it work to put it under the diff?
I would like to know. would helped me a lot nice BTW Philip |
08-01-2006, 08:39 PM
Post: #297
Because it isn't easy (for me, that i don't have short stroke conversion suspension) to have a compromise between having the pipe far from the ground and far from the rear axle.
I don't say that it isn't doable, but it gets a little expensive if you keep trying different distances... I'll keep trying to help as much as I can. But to be honest, if I knew what I know now about exhausts... I might have kept the stock exhaust for a looooooong time. No bang for the BIG buck. Best regards |
08-02-2006, 06:44 PM
Post: #298
Well, my car went to dyno again.
I've tested two different settings: 1st: - Ignition timing at 10º BTDC (stock) - Intake cam at stock angle - Exhaust cam at -4º (retarded) 2nd: - Ignition timing at 14º BTDC - Intake cam advanced 5º - Exhaust cam advanced 4º Joining both graphs Engine specs: ~ Camshafts - HKS 272in/264ex ~ KN Airfilter ~ Tsudo 4-1 Header ~ 2 1/4" exhaust pipe with mid muffler, ressonator and Apexi WS universal ~ Everything else stock (pistons, injectors, no fpr, etc) Right now, I'm disassembling the head to install the 0,5 mm TRD head gasket, to do some porting, change all guide bosses with copper ones, 3 angle valve job, and shave 1mm off. Then i'll try the same cams, and if the torque doesn't rise, i'll just throw in a 256º in the exhaust. Best regards |
08-03-2006, 02:13 AM
Post: #299
Head removed...
News soon... |
08-04-2006, 10:15 AM
Post: #300
ok...thx!
thought u had short stroke... can't wait 'til I see the dyno after mods keep up the great work Philip |
Toyota Corolla AE86 LEVIN ( Poland) | sylwekgtir | 40 | 54,043 |
11-23-2018 10:13 PM Last Post: sylwekgtir |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 14,742 |
RaceMinded satin black Toyota Corolla AE86 Levin Coupe | RaceMinded | 22 | 30,903 |
Shell make over a coat of paint | williep12 | 4 | 6,949 |
02-01-2010 03:52 PM Last Post: Kid Karola |
Repair/ Body | whitepoint | 6 | 8,204 |
03-12-2008 09:21 PM Last Post: whitepoint |
