Crank seal
02-14-2014, 06:30 PM
Crank seal
Is there any difference in the 4age 16v and 20v crank seals, 16v and 20v have different oil pumps, wath about the rear also?
02-14-2014, 10:57 PM
Crank seal
Also known as Timing Cover Oil Seal...
16V listed as 15100C Part #90311-32001 20V listed as 15100C Part #90311-32018 Toyota Parts Suppliers advise... Part #90311-32020 replaces: 90080-31014, 90311-32001, 90311-32002, 90311-32017, 90311-32018 So yes, as you might expect, same seal and used on a whole bunch of other Toyotas also... 4AFE, 7AFE etc. I'll leave it to someone else to look up the rear seal Cheers... jondee86 |
03-30-2014, 12:10 PM
Crank seal
the question was if there is any difference in material?or just for diamensions ?
4age 16v to FR 20VT |
03-30-2014, 10:43 PM
Crank seal
partnumbers change, supliers get replaced, thats why they change a lot for generic parts like oil seals... Some might be brown, some black, but they all do the same job...
04-09-2014, 02:28 PM
Crank seal
but finally they are all from silicone...?!
04-09-2014, 06:11 PM
Crank seal
they all have to be resistant to the same materials and oils, esspecially the ones that replace a bunch of different numbers.
04-10-2014, 03:04 AM
Crank seal
AFAIK the standard seals are black Nitrile rubber and the high
temperature seals (crank seals) are red/brown Viton. But since Viton is an elastomer, it can be made in different colours. It would be unusual to find silicone used for rotating seals, as it is better suited for static sealing, O-rings etc. Cheers... jondee86 |
04-12-2014, 09:36 AM
Crank seal
jondee86 Wrote:AFAIK the standard seals are black Nitrile rubber and the high thats the reason i asked...!as far as i know the siliocone seals could be in different color than black.I ve seen brown ones! 4age 16v to FR 20VT |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 17,526 |
08-16-2018 01:36 AM Last Post: Bean |
crank 6 bolt flywheel | DJexor | 5 | 8,164 |
12-05-2016 08:21 AM Last Post: d3nso |
Exhaust fumes in cabin (Hatch seal problem!) | Lt86 | 16 | 20,429 |
11-13-2015 01:20 PM Last Post: pack |
4ac crank on 4age! | Ghetto | 7 | 10,226 |
12-05-2014 10:42 PM Last Post: Uzelac |
Crank pulley without harmonic damper | Jan Pedersen | 21 | 23,747 |
05-21-2014 09:50 AM Last Post: Bean |
