Crank seal
02-14-2014, 06:30 PM
Crank seal
Is there any difference in the 4age 16v and 20v crank seals, 16v and 20v have different oil pumps, wath about the rear also?
02-14-2014, 10:57 PM
Crank seal
Also known as Timing Cover Oil Seal...
16V listed as 15100C Part #90311-32001
20V listed as 15100C Part #90311-32018
Toyota Parts Suppliers advise...
Part #90311-32020 replaces:
90080-31014, 90311-32001, 90311-32002, 90311-32017, 90311-32018
So yes, as you might expect, same seal and used on a whole bunch of
other Toyotas also... 4AFE, 7AFE etc. I'll leave it to someone else to look
up the rear seal Smile
Cheers... jondee86
03-30-2014, 12:10 PM
Crank seal
the question was if there is any difference in material?or just for diamensions ?
4age 16v to FR 20VT
03-30-2014, 10:43 PM
Crank seal
partnumbers change, supliers get replaced, thats why they change a lot for generic parts like oil seals... Some might be brown, some black, but they all do the same job...
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
04-09-2014, 02:28 PM
Crank seal
but finally they are all from silicone...?!
4age 16v to FR 20VT
04-09-2014, 06:11 PM
Crank seal
they all have to be resistant to the same materials and oils, esspecially the ones that replace a bunch of different numbers.
Gtsi-R
"Trust me, I was an engineer"
04-10-2014, 03:04 AM
Crank seal
AFAIK the standard seals are black Nitrile rubber and the high
temperature seals (crank seals) are red/brown Viton. But since
Viton is an elastomer, it can be made in different colours. It would
be unusual to find silicone used for rotating seals, as it is better
suited for static sealing, O-rings etc.
Cheers... jondee86
04-12-2014, 09:36 AM
Crank seal
jondee86 Wrote:AFAIK the standard seals are black Nitrile rubber and the high
Cheers... jondee86
thats the reason i asked...!as far as i know the siliocone seals could be in different color than black.I ve seen brown ones!
4age 16v to FR 20VT
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 17,506 08-16-2018 01:36 AM
  crank 6 bolt flywheel DJexor 5 8,156 12-05-2016 08:21 AM
Last Post: d3nso
  Exhaust fumes in cabin (Hatch seal problem!) Lt86 16 20,416 11-13-2015 01:20 PM
Last Post: pack
  4ac crank on 4age! Ghetto 7 10,217 12-05-2014 10:42 PM
Last Post: Uzelac
  Crank pulley without harmonic damper Jan Pedersen 21 23,742 05-21-2014 09:50 AM
