Digital Dash
09-30-2010, 04:10 PM
Post: #81
Digital Dash
bump.
my tacho works, now i just need water temp electric and rev. I found tachometer + and -. My tacho works. I'm not planning to use fuel gauge. but my fuel gauge illumination and water temp illumination did't work. Are they need different + and earth. ![]() shortly i'm not succeed to power on red circles and rev. other lights work. |
09-30-2010, 05:50 PM
Post: #82
Digital Dash
Possibly useful info for someone looking to tweak signals...
AE86 Analog sender resistance/voltage http://i223.photobucket.com/albums/dd186...uage_1.jpg http://i223.photobucket.com/albums/dd186...uage_2.jpg Cressida Digi sender resistance/voltage Fuel level Voltage Full 4.6-4.9 1/2 Tank 2.6 Empty 0.1-0.4 taken from http://www.aeu86.org/viewtopic/yes_-anot...051#113716 Doesnt indicate if signals are sigmoid or linear. http://www.skynet.ie/~eireae86 |
09-30-2010, 07:09 PM
Post: #83
Digital Dash
Here's something that i made after instaling my digi dash
i hope this can help ![]() From analogue to digital gauge cluster car:1985 left hand drive kouki 4age ae86 with analogue cluster install:(1984 jdm rhd digital gauge cluster) swap first your analogue fuel sender(partnr 83320-19715)with a digital fuel sender (partnr 83320-19725). Also swap the oil pressure switch with a digital one (one with just a oil light on the dash) One of a EP71,82,91/SW20/AE92/ST16x will do the trick Relocate the speedo cable from the right to the left(no need to buy a rhd cable its long enough) left plug of the digital cluster conected to the back of the cluster 1)Gauge fuse Red/blue stripe (5) 2)Tail fuse Black/brown dots (2) 3)Ground White/black stripe,pink dots (16) 4)Fuel sender gauge Yellow/red stripe (25) 5)------ 6)Rheostat or ground Green/brown dots (3) 7)Gauge fuse (same as nr 1) Red/blue stripe (5) 8)Ground Brown/black dots (26) 9)------ 10)Fuel level warning Yellow/blue stripe (24) 11)----- 12)Water temp sender gauge Yellow/green stripe (4) Right plug (white plug from left to right) 1)EFI computer Green/red stripe (7) 2)Door Red/white stripe (21) 3)Dome fuse Red/green stripe (20) 4)----- 5)Turn signal switch terminal left green/black stripe,brown dots (27) 6)Dimmer switch terminal Red/green stripe (12) 7)Ground Brown/black dots (19) 8)Turn signal switch terminal right Green/yellow stripe,brown dots (2 ![]() 9)Charge fuse Yellow (10) 10)IGN fuse Black/orange stripe (9) 11)Oil pressure sender gauge/switch Yellow/black stripe ( ![]() 12)------- 13)Brake fluid level/parking brake switch Red/black stripe (6) 14)Rheostat or ground Green/brown dots (3) The numbers behind the colors refer to the original location of the wires by page BE-22 from the AE86 manual some wires(like pwr/econ,vacuum switch) simply remain unused and are not needed daily driver avensis 2.0 d4d and Yaris 1.0 weekend driver 1985 AE86 |
10-01-2010, 08:41 AM
Post: #84
Digital Dash
Thanks for your answer. I made a mistake. The reason is my bad english
![]() Now everything works expect tach, fuel and temp. I don't need to use fuel and temp value. But i don't know why my fuel and temp illumination didn't work. Anyway my biggest problem is tach. I think its electric and earth is same as speed. am I wrong? When I try ignition cable to other pins i didn't succeed with tach. |
11-06-2010, 03:24 AM
Post: #85
Digital Dash
Hi, i want to try my digidash on table, so the dash is working, and i have the digi fuel sender, and i plug it into the dash according to diagram which was posted here, but fuel guage doesnt work. So can you help me to understand what is wrong.
I plug the yellow/red wire from sender to 04 pin on digidash, and white/black to 08 on dash (grd), so it's not working. First of all l found that between (on left pins) 04 plug and 08 plug on dash is about 5.8v dc when the dash is running. So i cant find is it my dash broken, or power to sender cames from dash? Did you know how the power came to sender? by which wire? So i dont know how can i check my sender, may be its broken.. I hope you can help me and sorry for my english, pleese ![]() Thanks |
09-08-2012, 11:30 PM
Post: #86
Digital Dash
Sorry for the digging.... i'm trying to get all the information to plug my digi dash on my Trueno...
But the schemes on the internetz don't match my wiring... AT ALL..... I'm kinda worried because i'll probably have to check all the wiring manually.... Damn... Anyone to help?! |
09-13-2012, 08:51 PM
Post: #87
Digital Dash
No one to help me on this?!
09-16-2012, 07:47 PM
Post: #88
Digital Dash
Assembled!
Thanks to roger and ilker_ae86! You guys were helpfull! ![]() |
11-20-2012, 05:05 AM
Post: #89
Digital Dash
this digi cluster was fitted to JDM GT Apex models only? i have seen some GTV Zenki models fitted with them too, not sure from factory or not.
02-09-2013, 01:48 PM
Post: #90
Digital Dash
Hi guys, I have a question. what designation remaining pin connector on the left digital dash.
2) Tacho 3) Ground 5) speed efi 9) nothing 11) nothing 13) nothing Tacho not work,must be connecting fuel sender,After the tacho works correctly. ![]() |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,534 |
Dash Waning Lights | pack | 7 | 4,484 |
10-06-2021 01:00 PM Last Post: pack |
Trueno Digital dash kph to mph | Bojack | 3 | 7,201 |
11-21-2018 12:27 AM Last Post: kazi |
Custom Dash Cluster | kazi | 14 | 20,679 |
10-24-2017 09:05 PM Last Post: kazi |
Dash Lights | kazi | 3 | 5,868 |
09-12-2017 10:04 PM Last Post: kazi |
