Doing a 7AGE build, gasket question
03-10-2010, 03:32 PM
Hello guys!
I found a nice 7AFE and started collecting parts, but now I'm stuck with head gasket. Since I bought hi-comp pistons from late 4AGE, I would need a 1mm+ metal head gasket. I have read in several places that I need metal gasket for 4AGE, but I cannot find the part number . Toyota dealership doesn't have a clue (which was to be expected, but I tried anyway). Does anyone have the part number, or will I have to go with some aftermarket solution? EDIT: It seems that 4AFE gasket has the right thickness - 1.4mm. I will have to find out if original toyota part is multi layer metal or.. |
03-10-2010, 04:57 PM
Stock 4A-GE head gasket = 11115-16070
Stock 4A-FE head gasket = 11115-16081 (05/1987-09/198 / -16082 (09/1988-08/1990) Stock 4A-FE head gasket for Avensis 1998 = 11115-16150 ( http://www.auto-parts.spb.ru/cat/oem_to....ent=dr2000 ) "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
03-10-2010, 05:30 PM
11115-16120
11115-16121 From 7AFE Celica AT200 |
03-10-2010, 08:11 PM
Which (if any) are the metal ones?
03-30-2010, 12:34 AM
any one from a 7AFE engine is a 3, lyer metal head gasket smae as the TRD one
Run Free and take a Goodline V8FOURCAM32 MK3 Supra Patchwork AE86 from 4AGE to 7AGE to 4AGZE and now 4AGEU20v suzuki cappuccino mondeo TD |
03-31-2010, 10:18 PM
H7ERO Wrote:any one from a 7AFE engine is a 3, lyer metal head gasket smae as the TRD oneExactly what I used, 7afe headgasket. And i have the high comp pistons as well. My evil Red/Black Panda http://www.bilgalleri.dk/html/gal_visbil.asp?ID=12832 My current JDM AE86 project http://www.bilgalleri.dk/html/gal_visbil.asp?ID=31609 |
07-14-2010, 01:15 AM
Şo, gasket thickness ?
Still not sure if 7afe is 1,4mm? |
07-14-2010, 08:57 AM
i have a HKS metal head gasket 1.6mm for sale. for 4AGE 16V
pm me if you are intressted toyota corolla coupe 1985 drift car toyota corolla coupe 1987 road car. |
07-15-2010, 12:42 PM
7AFE is 0.6mm, I'm using it as a cheap alternative of the TRD metal headgaskets. Although the cooling holes are a bit different on the 7AFE gasket, but nothing dramatical
7AGE Build | apardal | 5 | 508 |
08-02-2024 12:11 PM Last Post: apardal |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 20,488 |
timingbelt 7age 20V!! | slowboy2 | 3 | 6,675 |
06-21-2016 09:41 AM Last Post: ditn |
Oil leak (maybe a cylinder head gasket?) | max_ae86 | 15 | 16,529 |
11-30-2013 03:59 AM Last Post: jondee86 |
7AGE to W58, cluth type? | slowboy2 | 3 | 5,355 |
05-25-2013 01:37 PM Last Post: slowboy2 |
