ECU and Loom: Are they interchangeable?
01-04-2010, 12:58 AM
Hi!
Since I´m managing to put the 4AGE in my little KP61 in stock form, I need to know if the ECU and LOOM from an MR2 or FWD ´4AGE can me useable in one RWD 4AGE, since they are cheaper and more available! Thanks in advance for the replyes!! |
01-04-2010, 08:15 AM
Yes, you can use the ECU and loom from a front wheel drive but you'll have to alter the loom to fit. It won't be a straight fit in that some of the wires may not be long enough.
I've got a bigport running with a fwd loom (adjusted), and a JDM bigport ECU. |
01-06-2010, 09:00 PM
Tks Chrisso!!
Really nice Info! Will search for MR2 ECU + LOOM then |
01-11-2010, 06:00 AM
Just make sure you get the right loom/ecu for resistor pack/no resistor pack, and map vs afm.
I assume you'll run a map sensor, so just make sure it's a map sensored ecu/loom. With the resistor pack, it doesn't matter what you ran before, as long as you get the resistor pack and use it if that's what the ecu/loom was designed for. |
Can you identify this wheels? Will they fit AE86? | Ryo | 8 | 10,487 |
09-08-2021 12:48 PM Last Post: Ryo |
got seat belts. but they rolled up | MC_JP | 8 | 9,974 |
05-06-2014 04:04 PM Last Post: banpei |
Car shutting off and ECU making noise | rawb_dbap | 8 | 7,703 |
05-03-2013 11:51 PM Last Post: rawb_dbap |
Traction brackets what do they do? | slowboy2 | 4 | 9,856 |
03-25-2011 08:38 PM Last Post: NoHachi |
Electric mirror loom | hachirokuGTV | 12 | 13,540 |
04-29-2010 01:23 AM Last Post: parrot |
