ECU and Loom: Are they interchangeable?
01-04-2010, 12:58 AM
Hi!
Since I´m managing to put the 4AGE in my little KP61 in stock form, I need to know if the ECU and LOOM from an MR2 or FWD ´4AGE can me useable in one RWD 4AGE, since they are cheaper and more available!
Thanks in advance for the replyes!! Thumbs up!
01-04-2010, 08:15 AM
Yes, you can use the ECU and loom from a front wheel drive but you'll have to alter the loom to fit. It won't be a straight fit in that some of the wires may not be long enough.
I've got a bigport running with a fwd loom (adjusted), and a JDM bigport ECU.
01-06-2010, 09:00 PM
Tks Chrisso!! Thumbs up!
Really nice Info!
Will search for MR2 ECU + LOOM then Cool
01-11-2010, 06:00 AM
Just make sure you get the right loom/ecu for resistor pack/no resistor pack, and map vs afm.
I assume you'll run a map sensor, so just make sure it's a map sensored ecu/loom.
With the resistor pack, it doesn't matter what you ran before, as long as you get the resistor pack and use it if that's what the ecu/loom was designed for.
  Can you identify this wheels? Will they fit AE86? Ryo 8 10,491 09-08-2021 12:48 PM
Last Post: Ryo
  got seat belts. but they rolled up MC_JP 8 9,978 05-06-2014 04:04 PM
  Car shutting off and ECU making noise rawb_dbap 8 7,707 05-03-2013 11:51 PM
Last Post: rawb_dbap
  Traction brackets what do they do? slowboy2 4 9,857 03-25-2011 08:38 PM
Last Post: NoHachi
  Electric mirror loom hachirokuGTV 12 13,546 04-29-2010 01:23 AM
Last Post: parrot
