Effects of valve lift - worth it going higher?
03-15-2014, 04:40 PM
Where was peak torque with the ...138s? Wondering because I still fancy to switch to their ...148s or even 149s if peak isn't too high.
AE86 ex-daily |
03-15-2014, 05:44 PM
totta Crolla Wrote:Catcams say the same thing for their 9.5mm lift cams. Interesting question to ask.... @ 10mm of cam lift the cams DID just clear the castings..... ![]() ![]() but not by enough... Ted's said .015" I couldn't get a feeler gauge in there... but that looked to be closer than .015" to me, so I just made sure all the lobes would not have any issues ![]() Teds also has valve springs (additional option for valve springs) theirs have seat pressures of 62#s. For comparison stock is 35#s, HKS is 32#s, Toda and TRD are 52#s ![]() **IF** you go with high lift, "short duration" cams, and you use high seat pressure valve springs.... I STRONGLY recommend a kevlar toothed timing belt.... Rotating those cams ,pressing down those springs adds CONSIDERABLE forces upon the timing belt.... Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-15-2014, 07:59 PM
Well I never, HKS springs are lb rated lower than stock springs then.
I have not suffered valve float up to 8300rpm with HKS's and they allow at least 9.5mm lift so they are probably a good bet for sub 8500rpm and high lift cams. without putting undue stress on other components or robbing too much power. An analogue brain in a digital World |
03-15-2014, 08:09 PM
Bean Bandit Wrote:Where was peak torque with the ...138s? Wondering because I still fancy to switch to their ...148s or even 149s if peak isn't too high.I will try to find the printout for you Bean. An analogue brain in a digital World |
03-15-2014, 11:20 PM
Totta... not sure WHICH (if there are different ones) HKS springs you have... but the ones we tested are only good to low/mid 8mm of lift....
03-17-2014, 07:47 AM
@oldskewltoy
Good point with the timing belt. Can you recommend one in particular? This one sound serious: http://www.rhdjapan.com/power-enterprise...a-4ag.html |
03-17-2014, 09:12 AM
harkes Wrote:@oldskewltoy I got a TODA one but honestly either one of these will be fine... http://perfectrun.jp/quick/qui_home.php?...&submit=GO better prices than RHD AE86 ex-daily |
03-17-2014, 09:21 PM
I'm pretty sure I used a Power Enterprises timing belt, likely purchased through horsepower freaks ($160 today)
4AGE Valve Buckets Scored | Steller Engineering | 2 | 1,071 |
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 1,658 |
HKS valve springs | totta Crolla | 3 | 2,489 |
Valve clearance | leon205gti | 7 | 8,993 |
11-25-2016 03:24 AM Last Post: oldeskewltoy |
16v oversize valve seats | harkes | 9 | 12,893 |
09-20-2016 05:04 PM Last Post: oldeskewltoy |
