Effects of valve lift - worth it going higher?
03-15-2014, 04:40 PM
Where was peak torque with the ...138s? Wondering because I still fancy to switch to their ...148s or even 149s if peak isn't too high.
AE86 ex-daily
03-15-2014, 05:44 PM
totta Crolla Wrote:Catcams say the same thing for their 9.5mm lift cams.
I guess you need to relieve some of the head casting for 10mm lift ?
Interesting question to ask....
@ 10mm of cam lift the cams DID just clear the castings..... Huh
[Image: AEU86 AE86 - Effects of valve lift - wor...ng higher?]
but not by enough... Ted's said .015" I couldn't get a feeler gauge in there... but that looked to be closer than .015" to me, so I just made sure all the lobes would not have any issues
Teds also has valve springs (additional option for valve springs) theirs have seat pressures of 62#s. For comparison stock is 35#s, HKS is 32#s, Toda and TRD are 52#s
**IF** you go with high lift, "short duration" cams, and you use high seat pressure valve springs.... I STRONGLY recommend a kevlar toothed timing belt.... Rotating those cams ,pressing down those springs adds CONSIDERABLE forces upon the timing belt....
Dan -
03-15-2014, 07:59 PM
Well I never, HKS springs are lb rated lower than stock springs then.
I have not suffered valve float up to 8300rpm with HKS's and they allow at least 9.5mm lift so they are probably a good bet for sub 8500rpm and high lift cams. without putting undue stress on other components or robbing too much power.
03-15-2014, 08:09 PM
Bean Bandit Wrote:Where was peak torque with the ...138s? Wondering because I still fancy to switch to their ...148s or even 149s if peak isn't too high.
I will try to find the printout for you Bean.
03-15-2014, 11:20 PM
Totta... not sure WHICH (if there are different ones) HKS springs you have... but the ones we tested are only good to low/mid 8mm of lift....
Dan -
03-17-2014, 07:47 AM
@oldskewltoy
Good point with the timing belt. Can you recommend one in particular?
This one sound serious:
http://www.rhdjapan.com/power-enterprise...a-4ag.html
03-17-2014, 09:12 AM
harkes Wrote:@oldskewltoy
I got a TODA one but honestly either one of these will be fine...
http://perfectrun.jp/quick/qui_home.php?...&submit=GO
better prices than RHD
AE86 ex-daily
03-17-2014, 09:21 PM
I'm pretty sure I used a Power Enterprises timing belt, likely purchased through horsepower freaks ($160 today)
Dan -
  4AGE Valve Buckets Scored Steller Engineering 2 967 10-06-2023 05:34 PM
Last Post: Steller Engineering
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,484 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 2,308 05-25-2022 10:24 PM
Last Post: oldeskewltoy
  Valve clearance leon205gti 7 8,806 11-25-2016 03:24 AM
  16v oversize valve seats harkes 9 12,694 09-20-2016 05:04 PM
