Final Drive ratio - need advise
08-24-2011, 03:09 AM
Hi GUYs,
Need some advise from you here.
What's the ratio of the Beams 6s box, I want to change my final drive to suit it. Anyway my one now is far too noisy...and old.
Want to keep a normal rev. when doing a 100km cruising.
Also, any recommended brand? I want a stronger after market one as I am running a Beams.
It will be good if someone can teach me how to calculate the speed vs gear ratio vs engine rev. I am currently running a 195/55/15
Many thanks,
08-24-2011, 04:36 AM
Altezza (SXE10):
1: 3.874
2: 2.175
3: 1.484
4: 1.223
5: 1.000
6: 0.869
Finel Gear Ratio: 4.100
AE86: (for comparison)
1: 3.587
2: 2.022
3: 1.384
4: 1.000
5: 0.861
Finel Gear Ratio: 4.300
Personally if I were you I will use a 3.900 because hachi have smaller wheels than Altezza.
Weir Performance make 3.9 and 4.1 Wink (Toyota too)
08-24-2011, 07:14 AM
if you wont good pick up go the 4.3 ratio
as altezza s changed to a 4.3 later any way and the torque and power will be good about the same in 6th as what you have now
08-24-2011, 07:16 AM
Thanks a lot, super!
I shall consider your advise and check with Wier Performance.
THanks again. Thumbs up!
08-24-2011, 07:18 AM
Thanks also to Glenn.
BTW, I have source locally on the ECU, I think I will go for Links.
So, your adaptor can be soon in used.
Ah...I need some trumpet also..
08-24-2011, 07:27 AM
Just do a rough quick cal.
I can only do 75km/h in 3000 engine rev. with 6th gear and 4.3 final drive.
Please correct me if I am wrong...
I am using a 195/55/R15
08-24-2011, 08:12 AM
no you will be doing 90 kays with the 4.3 ratio and your tyres of 0.593 mm dia in 6th at 3000
08-24-2011, 11:00 AM
https://spreadsheets.google.com/spreadsh...y=CNqEs-cI
08-24-2011, 05:44 PM
THanks Glenn
And
Wonderful worksheet from Uze.
08-26-2011, 01:17 AM
Don't forget the option of 4.56, as that is the TRD final for the Altezza Wink
Our cars are much lighter, so probably not necessary tho.
Andrew
  Advise oldskull 14 13,783 09-04-2015 04:43 PM
Last Post: oldskull
  Final drive calculation. Aram 31 33,494 12-24-2014 03:08 PM
Last Post: Uzelac
  Ring & pinion ratio. izanagi 27 28,822 07-05-2014 07:35 PM
Last Post: assassin10000
  Gear end , drive pinion height filh 5 11,578 06-27-2013 12:29 AM
Last Post: filh
  5.375 final drive ratio with stock T50 4000GT 23 27,339 08-07-2012 01:08 PM
Last Post: 4000GT
