Final Drive ratio - need advise
08-24-2011, 03:09 AM
Hi GUYs,
Need some advise from you here. What's the ratio of the Beams 6s box, I want to change my final drive to suit it. Anyway my one now is far too noisy...and old. Want to keep a normal rev. when doing a 100km cruising. Also, any recommended brand? I want a stronger after market one as I am running a Beams. It will be good if someone can teach me how to calculate the speed vs gear ratio vs engine rev. I am currently running a 195/55/15 Many thanks, |
08-24-2011, 04:36 AM
Altezza (SXE10):
1: 3.874 2: 2.175 3: 1.484 4: 1.223 5: 1.000 6: 0.869 Finel Gear Ratio: 4.100 AE86: (for comparison) 1: 3.587 2: 2.022 3: 1.384 4: 1.000 5: 0.861 Finel Gear Ratio: 4.300 Personally if I were you I will use a 3.900 because hachi have smaller wheels than Altezza. Weir Performance make 3.9 and 4.1 (Toyota too) |
08-24-2011, 07:14 AM
if you wont good pick up go the 4.3 ratio
as altezza s changed to a 4.3 later any way and the torque and power will be good about the same in 6th as what you have now |
08-24-2011, 07:16 AM
Thanks a lot, super!
I shall consider your advise and check with Wier Performance. THanks again. |
08-24-2011, 07:18 AM
Thanks also to Glenn.
BTW, I have source locally on the ECU, I think I will go for Links. So, your adaptor can be soon in used. Ah...I need some trumpet also.. |
08-24-2011, 07:27 AM
Just do a rough quick cal.
I can only do 75km/h in 3000 engine rev. with 6th gear and 4.3 final drive. Please correct me if I am wrong... I am using a 195/55/R15 |
08-24-2011, 08:12 AM
no you will be doing 90 kays with the 4.3 ratio and your tyres of 0.593 mm dia in 6th at 3000
08-24-2011, 11:00 AM
Final Drive ratio - need advise | |||
08-24-2011, 05:44 PM
THanks Glenn
And Wonderful worksheet from Uze. |
08-26-2011, 01:17 AM
Don't forget the option of 4.56, as that is the TRD final for the Altezza
Our cars are much lighter, so probably not necessary tho. Andrew |
Advise | oldskull | 14 | 13,423 |
09-04-2015 04:43 PM Last Post: oldskull |
Final drive calculation. | Aram | 31 | 32,463 |
12-24-2014 03:08 PM Last Post: Uzelac |
Ring & pinion ratio. | izanagi | 27 | 27,836 |
07-05-2014 07:35 PM Last Post: assassin10000 |
Gear end , drive pinion height | filh | 5 | 11,279 |
06-27-2013 12:29 AM Last Post: filh |
5.375 final drive ratio with stock T50 | 4000GT | 23 | 26,573 |
08-07-2012 01:08 PM Last Post: 4000GT |
