Firehawk's N2 racecar project
06-25-2006, 07:15 PM
Post: #41
Great work firehawk .. Smile
2 NoHachi: how to get things from Ground Control, they don't ship internationally...
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
06-26-2006, 09:43 AM
Post: #42
Oh crap.. Friend of mine who works at the local Toyota dealer, checked for the price of the clutch member kit 41307-14011 which contains those two blocks. It seems that they are no longer available and out of production. So it looks like I'm pretty much screwed. Angry
If anyone has a worn out LSD or otherwise broken with the clutch members still intact, please contact me!
06-29-2006, 02:35 PM
Post: #43
Well, it seems that the clutch members are the parts which usually break in the original LSD if anything does break. This means that I have to buy a complete original LSD to replace the current one. Oh well..
On the bright side. my 4.778 final drive kit from SYM arrived! Big Grin Very nice, thank you! I started to calculate how the final drive affects the actual top speeds of each gear. If using the stock sized 185/60R14 tyres and a rev limiter at 7850rpm, on 5th gear, the top speed of the car falls from 231km/h to 208km/h and on 4th gear, the the rev limit kicks in at 179km/h instead of 199km/h. However, given that I'm considering using 195/45R14 tyres, the top speed of each gear would be as follows;
1st: 46km/h
2nd: 81km/h (~4400rpm=46km/h)
3rd: 119km/h (~5350rpm=81km/h)
4th: 165km/h (~5700rpm=119km/h)
5th: 191km/h (~6800rpm=165km/h)
Very nice and tight! Smile The shift from first to second drops the revs a bit low but first gear usually isn't that much needed anyway when driving on a track.
If you want to calculate the speeds on different gearings and tyres, here's something I made quickly at work (hahaa); OpenOffice / Excel. Have fun. Smile
I also re-arranged the project image gallery because I had to switch servers - while I was at it, I added some new photos of the current progress;
http://www.r5r.net/gallery/v/projects/ae86/
Edit: updated the spreadsheets to new ones that show also the upshift RPMs.
06-29-2006, 03:28 PM
Post: #44
This diff parts are available but costs more than 400 euros as the diff itself from Toyota costs more than 1.000 euros Huh
So, get yourself a good used TRD one from Jp.
[Image: AEU86 AE86 - Firehawk's N2 racecar project] http://www.jdmbits.com
06-29-2006, 04:26 PM
Post: #45
nmwisima Wrote:This diff parts are available but costs more than 400 euros as the diff itself from Toyota costs more than 1.000 euros Huh
Well, actually I was thinking of buying a second-hand zenki LSD from TE71Corolla and using the clutch members to fix my kouki one. Smile I already ordered the clutch plates, washers and springs from Toyota some time ago so they'd become quite useless if I went for a TRD 2-way instead.. Might be nicer to learn the car with the OEM 1.5-way first, anyway.
06-29-2006, 05:24 PM
Post: #46
I liked the 1,5 way very much Smile
06-29-2006, 09:00 PM
Post: #47
Well done that man, a very worthy owner of an AE86 by the sounds of things Thumbs up!
07-03-2006, 08:31 PM
Post: #48
Aargh, still a little more to go... Smile
07-03-2006, 08:47 PM
Post: #49
firehawk Wrote:Aargh, still a little more to go... Smile
Ahhh If i'll hat this all this room for rebulding my 86 Yummie! Big Grin
Keep the good job Wave :wink:
SR Team
BURN THE RUBER NOT YOUR SOUL!
07-07-2006, 03:47 PM
Post: #50
Hmm, I took the rear light clusters, signals, front corners and the front panel home with me and polished the surfaces a bit with some fine rubbing compound. While making a smooth surface for the front Levin-sticker, I noticed that the "TOYOTA" -text on the front mask is slightly raised from the surface. Have you guys just slapped the sticker on top of it (after removing the white paint, of course) or first wetsanded it down and re-polished?
Oh, and here's some updated versions of the gearing calculator, now with some graphical illustration (anyone remember tweaking gearing in the original Gran Turismo); OpenOffice / Excel
  ae86 racecar with beams engine bakonick 148 164,769 04-23-2024 10:06 PM
Last Post: bakonick
  Racecar: TRD USA built ITA AE86 oldeskewltoy 38 43,144 07-22-2019 02:55 PM
Last Post: apardal
  S.K.s AE86 racecar S.K. 207 223,706 09-18-2016 11:39 AM
Last Post: totta Crolla
  Jonny's Levin Racecar Jonny Rochester 9 12,123 01-03-2010 04:34 PM
Last Post: woper
  Another AE86 build up - Racecar Jan Pedersen 18 20,545 06-09-2008 03:34 PM
Last Post: Jan Pedersen
