Fitting a TRD/CBY N2 front lip
03-23-2011, 09:59 PM
Hi guys
I just bought a TRD/CBY style N2 fronlip from MCNSports, but when I tryed to fit it on my Zenki bumper, it has a 10mm gab between bumper and lip in the corners. Confused
The question is, how high it should be mounted on the bumper?
Does anyone have some closeup pics or some messurements?
If I should mount it higher, I will need to cut holes in the bumper, for the airducts Huh
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v Turbo, 200hp
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Star...079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
03-24-2011, 12:22 AM
Isn't the TRD lip supposed to go with the TRD widebody? They meet the widened fenders, not the stock ones.
03-24-2011, 07:57 PM
Well, not the CBY one, but if you buy the original TRD, it only fit with flares.
I will try to take some pics to better explaine the problem.[/img]
Cars I have owned:
03-29-2011, 01:01 PM
i know your problem, yes you will have to cut slots out of your bumper to allow duct to pass. if you dont want to cut your bumper you could cut the duct back so it passes the bumper bottom. If you dont do either of these the lip will point downwards. I didnt get mine from mcnsport but mine is 10/20mm too big as well but when you actually start fitting it, it will come in also you can fit a longer bumper support bar and push the bumper corners out to meet it. hope that helps
03-29-2011, 07:32 PM
Thanks man. Can you do me a favour, and show me a closeup pics? Or messure the distance here? I will really appreciate it
[Image: AEU86 AE86 - Fitting a TRD/CBY N2 front lip]
Cars I have owned:
03-30-2011, 01:38 PM
no problem i will do that tonight BUT i am fitting a TRD kit so i HAD to cut slots in the bumper in order to line with the arches/kit properly but you are not fitting that kit so you might get away without cutting the slots? i wouldnt go cutting the bumper if its in good condition when you dont need to?
03-30-2011, 07:29 PM
Maurice Wrote:i wouldnt go cutting the bumper if its in good condition when you dont need to?
Exactly, my bumper is in MINT condition Smile
Cars I have owned:
03-30-2011, 07:50 PM
Fitted up my TRD kit without cutting any of the front bumper away . ??
Your addiction to motorsport can only be cured by poverty !!
03-30-2011, 08:34 PM
nzae86 Wrote:Fitted up my TRD kit without cutting any of the front bumper away . ??
I have seen alot on your picture, but I can't se how high you have mounted it. Undecided When I fit it without cutting, it have some huge gabs all way around. Mayby I should just fill it with resin and fiberglass :wink:
Cars I have owned:
  Fitting Air Con (No PS) to LHD AE86 pack 7 4,249 01-07-2024 11:36 AM
Last Post: CCB
  Fitting Fibreglass Kouki Lip? chrisae86 3 2,145 02-25-2022 08:14 PM
Last Post: chrisae86
  Fitting driftworks CS2 coilovers bozu 2 4,753 05-30-2017 10:50 AM
Last Post: bozu
  goodridge SS brake lines fitting doubts wouter86 17 17,403 04-30-2014 06:33 PM
Last Post: wouter86
  Flywheel fitting totta Crolla 11 12,878 11-24-2013 05:31 PM
Last Post: Apsogos
